01 B18C5 making odd noise
Old Sep 2, 2003 | 07:59 AM
KRiS1's Avatar
Default 01 B18C5 making odd noise
Motor makes an odd noise after I shut it down. It makes a loud thunk every couple of minutes for about a half hour after I shut it down. Also it takes FOREVER to cool down and runs a little on the warm side. Any ideas as to what may cause this?
Old Sep 2, 2003 | 09:38 AM
RaVAGE00's Avatar
New User
Default Re: 01 B18C5 making odd noise (KRiS1)
if its under warranty... bring it in.
Old Sep 2, 2003 | 09:45 AM
xtrafastcivic's Avatar
Default Re: 01 B18C5 making odd noise (RaVAGE00)
is it a dripping noise?
Old Sep 2, 2003 | 09:46 AM
KRiS1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">if its under warranty... bring it in.</TD></TR></TABLE>
nope no warranty as its just the motor/trans in my hatchback
as for a dripping noise, I dont think I would call it that
Old Sep 2, 2003 | 10:17 AM
Denny's Avatar
if its a pinging noise its normal. dont know about a clunk
Old Sep 2, 2003 | 11:47 AM
Nuts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRiS1 &raquo;</TD></TR><TR><TD CLASS="quote">Also it takes FOREVER to cool down and runs a little on the warm side. Any ideas as to what may cause this? </TD></TR></TABLE>
elaborate on this? you mean the temp show on the temp. gauge is higher than normal temp. (a little below the mid point)? takes forever to cool down????
Old Sep 2, 2003 | 01:57 PM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRiS1 &raquo;</TD></TR><TR><TD CLASS="quote">It makes a loud thunk every couple of minutes for about a half hour after I shut it down. </TD></TR></TABLE>
Probably just the exhaust system cooling.
More detail please.
Old Sep 2, 2003 | 03:28 PM
KRiS1's Avatar
Default Re: 01 B18C5 making odd noise (01-1194)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1194 &raquo;</TD></TR><TR><TD CLASS="quote">
elaborate on this? you mean the temp show on the temp. gauge is higher than normal temp. (a little below the mid point)? takes forever to cool down????</TD></TR></TABLE>
The temp needle reaches the half way mark and holds steady after about 60 seconds of normal driving. I can leave the hood popped and the car off and after about 6 hours the motor will still be really warm. when I had the valve adjustment done, the mechanic also commented about the car taking longer than normal to cool down to the point where he could work on it.
Old Sep 2, 2003 | 04:09 PM
Big Phat R's Avatar
The temp needle reaches the half way mark and holds steady after about 60 seconds of normal driving. I can leave the hood popped and the car off and after about 6 hours the motor will still be really warm. when I had the valve adjustment done, the mechanic also commented about the car taking longer than normal to cool down to the point where he could work on it.</TD></TR></TABLE>
Check your coolant and oil. Temp needle is coolant temperature btw.
As long as it is going halfway and not higher - that's normal.
As for working on the car when it's hot - use gloves? What's the problem?
De_tour
12
Aug 3, 2007 05:55 PM
mportracer33
Honda S2000
Apr 6, 2007 10:11 AM
jesseb01x
Honda S2000
Nov 19, 2006 12:02 AM
S2000Forsale
Honda S2000
25
Sep 18, 2005 09:21 PM
thatboi
Jul 13, 2003 12:38 PM
