How long do new springs take to get the full drop?
Hi all,
A friend and myself have both fitted -35/-40mm springs to our ludes 3 days ago, the rears have dropped 30mm but the fronts have only dropped 10mm....?
Does anyone know how long it can take to get the full drop?
We've both stuck with std shocks as money is an issue atm, we didn't do anything to the 'stoppers' on the shocks either.
Thanks
Dave
Thanks
Dave
ehhhhhhhhh - to get the correct ammount of drop, it should take between the time you push the "down" button on your lift to when your car is sitting on the ground. I'd be pretty concerned if my springs were progressively letting my car down on a day-to-day basis.
your car should be as low as its going to go after you install the springs. you probably need to trim the bumper stops. I dont think the shocks are the problem, i have been dropped on stock shocks for 6 years with not probs at all
Yep the springs are definately on right, and the right way up.
I'm getting a bit of conflicting advise between here, hondarevolutions and po.com
Thanks anyway.
Dave
Thanks anyway.
Dave
it took the springs on my TEIN SS about 1 - 1 1/2 days to fully settle...how do i know?? i measured....when i went to go pick the car up from the shop after they were installed i looked at the drop afteri went to pay for everything the left front was a bit lower than the right front..all is good now
muddmonky
Suspension & Brakes
Jul 16, 2012 07:16 AM
crxaddikt
Sep 6, 2002 05:41 AM
