Zc Parts on a D16?
Due to a cracked head, I've got to swap out my nephew's ZC in his 91 Si. I have a D16 in the garage we are going to replace it with. Will the alternator,throttle body and fuel injectors from the ZC work on the D16?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhatThaFrig »</TD></TR><TR><TD CLASS="quote">Due to a cracked head, I've got to swap out my nephew's ZC in his 91 Si. I have a D16 in the garage we are going to replace it with. Will the alternator,throttle body and fuel injectors from the ZC work on the D16?</TD></TR></TABLE>
yes
yes
the alternator and injectors should work. i am not sure about the TB, but i think it will too.
i thought i heard the ZC injectors had a high CC rating than the Si ones. you might want to find out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv »</TD></TR><TR><TD CLASS="quote">the alternator and injectors should work. i am not sure about the TB, but i think it will too.
i thought i heard the ZC injectors had a high CC rating than the Si ones. you might want to find out...</TD></TR></TABLE>
The TB works, I have both, and I haven't checked out the injector's - although it's not a definative answer- they appear to be the same.
alternator, compatibility, compatible, d16, fuel, injector, injectors, parts, stock, swap, swapping, zc
