Is it critical to have the crank installed before torqueing down the head?
Old Sep 2, 2003 | 04:40 AM
94gsr's Avatar
Default Is it critical to have the crank installed before torqueing down the head?
I can't install my crank yet because I still have to get some main bearings. I need to know if I can reinstall my head & torque it down without worrying about the block twisting due to the absence of the crank. Knowledgeable input would be appreciated. Thanks.
Old Sep 2, 2003 | 04:50 AM
BeerMan's Avatar
Default Re: Is it critical to have the crank installed before torqueing down the head? (94gsr)
removed for stupidity
Modified by BeerMan at 10:15 AM 9/2/2003
Old Sep 2, 2003 | 05:10 AM
94gsr's Avatar
Default Re: Is it critical to have the crank installed before torqueing down the head? (BeerMan)
You can pull/install a crank without removing the head.
Old Sep 2, 2003 | 06:09 AM
BeerMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr &raquo;</TD></TR><TR><TD CLASS="quote">You can pull/install a crank without removing the head.</TD></TR></TABLE>
I answered before I had my morning coffee.
Old Sep 2, 2003 | 07:21 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr &raquo;</TD></TR><TR><TD CLASS="quote">I can't install my crank yet because I still have to get some main bearings. I need to know if I can reinstall my head & torque it down without worrying about the block twisting due to the absence of the crank. Knowledgeable input would be appreciated. Thanks.</TD></TR></TABLE>
the twisting won't be as severe, if you really have to and use a block girdle that will help some ...
You risk scarring your sleeves from having the rods and pistons sitting in cylinder from the rods hanging back and forth and there are 4 of them swinging while you're manuvering the crank.
So you really should just wait for mains, install the crnak then install the pistons rods then the head. Patience is everything when it comes to motor assembly.
Greg
Tyler Godley
Engine Machining & Assembly
10
Feb 24, 2019 07:49 AM
johnzm
Sep 29, 2006 03:20 PM
siis2fast
Jul 8, 2005 11:47 PM
johnzm
Jan 24, 2005 05:28 PM
dynomax27
Apr 20, 2003 12:13 AM
