How much Hp Gain from CTR CAMS in b16?!?!?!
yes ive searched.....not enough information...i want to know how much gain i would get from ctr cams in a stock b16 2nd gen........stock header, intake....with stock internals....thanx....
i use skunk2 stage 1's with some tuning and gained about 15whp. they a little more pricey but they feel great when vtec kicks in. i have my vtec set at 5200rpms, it seems to be the optimum engagement point. all motors are different so ur local tuner should be able to find the best for u. hope i helped u at all.
kwikb16.....think ive talked to you before at INFINEON raceway once....you came late and it was dial in time.....hahah thanx for info.....not tryin spend ridiculous money on car right now....but gettin cams for dirt cheap from a homie......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi »</TD></TR><TR><TD CLASS="quote">i made 18whp from
itr cams
ctr header
cheap intake
2 1/2 inch cat > exhaust
thats a god dyno, imade 156 ith JDM DC 4-1 2.5 exhaust and skunk2stage1 with some minimal tuning.
u need a VAFC/FPR or something to tune a/f before the cams go in or you wont behappy
itr cams
ctr header
cheap intake
well, i dont have anything to tune it with the exception of cam gears,
its pointless unless you at least have a bigger header and exhaust to breath, otherwise you might gain 5 whp from them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">the skunk2 stage1 would not idle without VAFC tuning. it would stall out</TD></TR></TABLE>
who they hell told you that nonsense? why would stage 1 not idle correctly, when the stage II idles perfectly fine? the only one that idles rough is the stage III from skunk2. even when my my friend vu (al bundy) had his jun III those idled perfectly fine w/ absolutly no tuning
hopefully i will notice something at least......im not expecting a **** load b/c obviously im running bone stock basically......onlything done is a basic tune, cap rotor, plugs wires **** like that and 2 1/4 in piping with exhaust....other than that ....its stock.... thanx fellahz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg »</TD></TR><TR><TD CLASS="quote">
who they hell told you that nonsense? why would stage 1 not idle correctly, when the stage II idles perfectly fine? the only one that idles rough is the stage III from skunk2. even when my my friend vu (al bundy) had his jun III those idled perfectly fine w/ absolutly no tuning</TD></TR></TABLE>
stop talking idiot and you wont look any worse. i HAVE skunk2 stage 1's and they WILL NOT idle without fuel correction. now if you dont have anything important to say, stop talking
BTW this is my dyno with the stage 1 cams and not enough tuning. i have over 160whp now but do not have a dyno to show : /
