the R wont start
Old Sep 1, 2003 | 09:16 PM
CDN Yellow ITR's Avatar
Default the R wont start
like the title says my R won't start
i can still bump start it np, tired jump starting with cables no good cuz i just got a new battery, rad fan turns on when i try to start it.
what do you think the problem is
Old Sep 1, 2003 | 09:41 PM
.RJ's Avatar
.RJ
Default Re: the R wont start (CDN Yellow ITR)
are your battery terminals still good (not caked with corrosion)
Old Sep 1, 2003 | 11:02 PM
Default Re: the R wont start (.RJ)
yah there fine no rust or nothing like that in the engine bay
a few of my friends think its the ignition????
can that be it?????
-tony
Old Sep 1, 2003 | 11:08 PM
B U N M A N G O's Avatar
does it crank? or does it just click? could be the ignition... the starter motor... fuel problem... lots of things. Can you be more specific?
Old Sep 1, 2003 | 11:34 PM
Default Re: the R wont start (B U N M A N G O)
no noises what soo ever the only thing i could hear is the rad fan
is this a biggie on the wallet or what???
Old Sep 1, 2003 | 11:52 PM
98cwtypeR's Avatar
alternator?
Old Sep 2, 2003 | 01:28 AM
arren123's Avatar
I'm no mechanic, but sounds to be if you can bump start it and it runs fine without problems (it doesn't die while idling), then it could be a problem with your starter. Put your car in neutral and the ignition on. Then hook up a jumper wire from your starter motor and touch it to the positive terminal. If it doesn't crank, then it could be your starter motor or it could be that your battery doesn't have enough juice.
Old Sep 2, 2003 | 02:27 AM
machgo5go's Avatar
Call CAA and tow it to the expert.
rc.square24
Mar 18, 2013 11:54 PM
BistaYang
Jan 28, 2013 07:35 AM
jimboek
Apr 26, 2007 07:12 PM
whatcivic
Dec 6, 2005 05:20 PM
brinks
Sep 19, 2002 02:39 AM
