After clutch for 98 gsr
Need a new clutch for a 98 gsr. What brand or type should I get. Car has basic mods only. Intake, exhaust etc. Any help would be appreciated
i need a new clutch also... i am torn between the "ACT", and the "CLUTCHMASTERS STAGE 3". from the info i have aquired these are the 2 best on the market.. any suggestions???
Your car is a 98 and you need a new clutch? Poor thing...
I recommend that you get a light weight flywheel while you are doing the clutch. It only makes sense since you are going to have it out anyway.
Here are your two options:
If you want a pucked clutch, DEFINATELY go with a ClutchNet 6puck (sprung hub) and the HD pressure plate.
If you want a disc clutch, the ACT street disc is great w/ a HD pressure plate.
Dustin
Dustin
hey everyone,
im doing an ls/vtec setup and im going to be using a gsr tranny and im confused on what clutch to get. someone told me that the clutchmasters stage 3 is a great clutch and ACT clutches suck. so i need your opinions of owners out there. im going to have basic bolt ons.
thank you
thank you
BoostedVtecGsr
Mar 14, 2005 06:57 PM
