Quaker State High Mileage oil?
Old Sep 1, 2003 | 08:04 PM
LudemanDan's Avatar
Default Quaker State High Mileage oil?
A mechanic recommended it to me. Looking for more opinions.
Old Sep 2, 2003 | 07:04 AM
Swift's Avatar
Default Re: Quaker State High Mileage oil? (LudemanDan)
stay away from quaker-sludge, castrol makes a high mileage oil.
castrol
Old Sep 2, 2003 | 11:40 AM
darkstar17's Avatar
Default Re: Quaker State High Mileage oil? (Swift)
I personaly would go with Mobil 1 full synthetic, but keep an eye on it you will burn up a little more than if running conventional
Old Sep 2, 2003 | 12:06 PM
Nextelbuddy's Avatar
Default Re: Quaker State High Mileage oil? (darkstar17)
is it tru that synthetic oil tends to burn up faster than conventional oil? because i have been running a synthetic blend and it has been dissapearing on me but i have no oil leaks
Old Sep 2, 2003 | 12:35 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudemanDan &raquo;</TD></TR><TR><TD CLASS="quote">A mechanic recommended it to me. Looking for more opinions. </TD></TR></TABLE>
I use it on my Escort, I dont think id use it on my Honda though
Old Sep 3, 2003 | 09:00 AM
ejprimo's Avatar
Default Re: Quaker State High Mileage oil? (TeStUdO)
you should stick with castrol or pennzoil high mileage oils. both are better than the synthetic blend oils.
Old Sep 3, 2003 | 09:26 AM
Grimm's Avatar
Default Re: Quaker State High Mileage oil? (ejprimo)
I used to use Mobile 1 syn... I switched over to Castrol High Mileage. Definatly holds up better than the mobile 1.
Old Sep 3, 2003 | 10:05 AM
TheDingo8mybaby's Avatar
Default Re: Quaker State High Mileage oil? (nextelbuddy)
More than likely it is leaking somewhere...
Synthetic oil tends to leak through seals quite a bit more than conventional oil. Do you have any white smoke on start up after it sits a while?
Old Sep 3, 2003 | 06:13 PM
LudemanDan's Avatar
Default Re: Quaker State High Mileage oil? (TheDingo8mybaby)
How did we get on the subject of synthetic oils? I don't use synthetics, I'm not planning to, and I never mentioned them.
I know my car burns some oil. Actually, a mechanic today recommended I switch to 10w-40. I'm thinking of trying that.
Edit: my car has 138k miles. At 2500-3000 mile intervals, when I change my oil, it's totally black.
dnoonkeste
Honda Civic (2001 - 2005)
Jun 28, 2011 10:47 PM
spartans2
Oct 19, 2010 10:24 AM
FoxRiderH22A
Jul 3, 2009 06:30 AM
chaserz
24
Oct 4, 2008 03:27 PM
in4mation
Dec 27, 2005 01:27 PM
