srs light
Old Sep 1, 2003 | 07:44 PM
integra pride's Avatar
Default srs light
my srs light never goes on not even b4 the car start
i was told there are airbags
is it even if there are no airbags the srs light will be on all the time
need help on that
Old Sep 1, 2003 | 08:05 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: srs light (sauado)
the bulb is probably burned out, as it should be on if there is a problem. Go ahead and replace it so that you will be able to see it if there ever is a problem and it does come on. My dad survived a near-head-on crash at 60+ mph w/ no injuries at all back in June, and I attribute that 100% to the seat belts and airbags, so you always want to make sure they are functional.
Old Sep 1, 2003 | 09:32 PM
how do i replace the bulb and is it located in the back of the cluster
thx
Old Sep 11, 2003 | 06:55 PM
DumpedSi's Avatar
Default Re: srs light (usdm integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm integra &raquo;</TD></TR><TR><TD CLASS="quote">how do i replace the bulb and is it located in the back of the cluster
thx</TD></TR></TABLE>
no, the bulb is located in the engine right next to the tranny...j/k, chances are the seller who sold you the car pulled the bulb because the SRS light was on. All you have to do is remove the cluster, flip the SOB over and look to see which one is the srs light plugs into, I'd just try a bulb next to it to see if thats the problem
Bleakened
Dec 12, 2014 12:29 PM
eaz_e
Aug 19, 2008 04:00 PM
Slava.
10
Apr 29, 2006 07:33 PM
KayOs
Aug 15, 2003 03:35 PM
CaRiXma
Apr 13, 2003 09:51 AM
