intermittent sputter on highway
Old Sep 1, 2003 | 05:59 PM
type Gendy's Avatar
Default intermittent sputter on highway
Last wkend i go away with the whip, about a 5 hr drive. About 3.5 hrs into the drive it starts to stutter and lose power under light throttle. If i gave it full throttle it would jump out of it and keep going like normal. No codes. IT feels like the o2 problem i was having for a while when they were wired backwards. This happend at 1am, so it wasnt like it was a long drive in burnign heat. Next day it is fine.
2 wks later as i am moving up to school, 1 hr drive, it starts to do it again.... SEems to only do it on long trips. Anybody have an idea WTF is up here?
Old Sep 1, 2003 | 06:54 PM
Stupid Ass's Avatar
Default Re: intermittent sputter on highway (sick hatchem)
Yep... just had this problem recently.
Changed spark plugs... problem fixed.
Old Sep 2, 2003 | 08:38 AM
type Gendy's Avatar
Yeah, still gotta try that, i am hoping thats it, thanks.
Anybody else experience this problem??
Old Sep 2, 2003 | 08:41 AM
EF_LSVtec's Avatar
Default Re: (sick hatchem)
Had the same problem a while back...replaced my O2 sensor to a 4 wire O2 and solved it. You probably may not have to switch to a 4 wire but another O2 sensor would do.
Old Sep 2, 2003 | 08:45 AM
ThatRicerDaniel's Avatar
ignitor
Old Sep 2, 2003 | 07:32 PM
allmotorsircrx's Avatar
i'm having this same problem too, but i've replaced everything but my throttle body and i need to try that o2 sensor suggestion. and what's wrong with my t/b is the fast idle valve plate on teh bottom is missing the plate. so that might have something to do with it. we'll see.
Old Sep 2, 2003 | 08:52 PM
sleeper4dr's Avatar
you might also want to check the vacuum connection on to your MAP sensor. i had what seemed like a sporadic bogging/sputter problem like this also. it turned out that the vacuum connection to my MAP was loose and sometimes it would come close to freeing itself (causing a very rich mixture).
sometimes loose distributor rotors can cause similar symptoms but i doubt its your problem right now.
let us know what cures your problem.
J
Old Sep 3, 2003 | 12:34 PM
type Gendy's Avatar
I haven't had a chance to pop the hood and change the plugs yet because i am back at school and afraid to lift my hood in this city.
Where is the map sensor located so i can check that out though, when i do... I can't remember
Old Sep 3, 2003 | 03:08 PM
sleeper4dr's Avatar
follow your vac. lines to the firewall. it looks like a little black box with a connector on one end and a vac. line connector on top of the 'box'.
peterkemp47
Aug 11, 2016 01:38 PM
ADAMnQuickRDX
13
Sep 5, 2009 06:33 PM
tuname420
Engine Management and Tuning
Sep 15, 2008 12:37 AM
Black R
Sep 11, 2002 12:33 PM
HXMan
12
Nov 19, 2001 07:26 PM
