P0B EcU
Old Sep 1, 2003 | 04:50 PM
Mrivera21's Avatar
Default P0B EcU
Hey Fellas,
Well I tried replacing my ECU with another EcU from a 2000 accord......Might of worked if the EcU was reprogrammed (FYI....2000 accord ECUs hold the imbobilizer system so in order to change one out it has to be reprogrammed by the dealer ) anyway...so I decided to go ahead with an ODBI conversion, my only question to you is will a 95 accord ECU work without any problems AND does it have to be reprogrammed like the 2000 ECU did. The ECU I bought is a PART# 37820-P0B-A01
Thanks again guys...
Also I have 2 2000 ECUs for sale....CHEAP will give em both up for 35 bucks plus shipping..
Old Sep 2, 2003 | 07:27 AM
KTeller8's Avatar
Default Re: P0B EcU (Mrivera21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrivera21 &raquo;</TD></TR><TR><TD CLASS="quote">Hey Fellas,
Also I have 2 2000 ECUs for sale....CHEAP will give em both up for 35 bucks plus shipping..</TD></TR></TABLE>
ok first off, this is a five speed car right? If so then you need the obd2-1 harness and the ecu from the obd1 car..
bout it... nothign will be redone or configured:
94-95 ecu will work the best: Ex if he has vtec and i am sure he can go from there
Old Sep 2, 2003 | 06:51 PM
Mrivera21's Avatar
Default Re: P0B EcU (KTeller8)
Unfortunatly it is not a 5speed but an automatic....Is there anything I can do????
Old Sep 2, 2003 | 09:23 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrivera21 &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunatly it is not a 5speed but an automatic....Is there anything I can do????</TD></TR></TABLE>
well with an auto, you need to have the tranny and ecu seperated
normal obd2=1 harness will do this by the ecu, not the wiring of a ecu and TCU/TCM transmisson control unit/module
but i only know of one person or one place in the world that will do this for the auto
2kaccord
Jan 24, 2006 10:41 PM
James
Feb 23, 2004 11:29 AM
