wtb: g3 integra rear passenger *trailing arm*
From: gravity rides everything...everything will fall, se GA/ne FL
i have one off a '96 ls clean off unwrecked car. do you need the whole assembly with the brake stuff? im or respond back. i just happen to have a passenger side whole rear arm with disk and caliper. i have lots of references if you want and if you need pics i can provide. thanks.
-kevin.
-kevin.
whole assembly 125 shipped...just arm, hub, and uca and lca for 100 shipped. let me know how that sounds please it's kinda heavy.
can you take a photo of the WHOLE assembly? let me confirm..
this will fit on a GSR sedan, it's for the rear passenger side. right?
yeah it will fit on a sedan and it's the rear passenger side trailing arm assembly. i don't have a digital camera on hand i always have to use my friend's.
ok sure will do probably be posted tonight late or early tomorrow as a heads up. going to get my new hatch and borrow friend's cam now.
125 for it shipped right?
can you include all mounting screws or what ever?
how hard will it be for me to have it replaced on my own car? I noticed there is an brake line or abs line and I remember someone said it's a bitch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless »</TD></TR><TR><TD CLASS="quote">125 for it shipped right?
how hard will it be for me to have it replaced on my own car? I noticed there is an brake line or abs line and I remember someone said it's a bitch.</TD></TR></TABLE>
yes 125 shipped for everything in the pics. i don't think i have the mounting hardware to the chassis...i can check but if you are just replacing then you just use your old ones. i don't think it's a bitch to take the whole assembly apart much less change out the abs sensor and also swap ebrake cables. it has the soft stock brake line on it also. rotors good just a little rust and there is lots of meat on the pads still. easy bolt on deal here...you probably should get back aligned though.
do you accept paypal?
and I'm unfamilar with what you meant by "you probably should get back aligned though."
yes i accept paypal. i just say get alignment after you install it because your eye is not going to put it on straight...you'll understand what i mean once you put it on. because you can adjust the toe in and toe out. my paypal is b18bhybrid@hotmail.com if you want to get the show on the road. if you need any references, then i shall drop some very reputable names on you.
sure, drop these names on me
I'll have the payment sent before monday so please get the stuff ready to ship on monday
thanks
thanks
just a couple vouches:
-b18c1_powered_si
-topspeed86
-ivan
-slofu
-euclid
-93lsivic
-b18c1_powered_si
-topspeed86
-ivan
-slofu
-euclid
-93lsivic
thanks loveless for helping me clear out space in my garage
. will go out tomorrow. you'll have the confirmation once i have it.
g3Gsr443
Oct 31, 2007 03:01 PM
