95 Accord won't come out of drive. HELP!
Old Sep 1, 2003 | 02:53 PM
Chris93Si's Avatar
Default 95 Accord won't come out of park. HELP!
Well my sisters car won't come out of park, it'll come out when you use the key to unlock the shifter but not unless you do that. I'm assuming there is some type of interlock or relay that tells the transmission whether or not the brake is on and allows you to shift outta drive and that maybe it has gone bad. So what do you guys think? Is this a common problem? Thank you very much for any help!
Modified by Chris93Si at 7:52 PM 9/1/2003
Old Sep 1, 2003 | 04:15 PM
civicVX's Avatar
Default Re: 95 Accord won't come out of park. HELP! (Chris93Si)
do the brake lights work? if they don't most likely it is a bad brake switch.
Old Sep 1, 2003 | 04:17 PM
Chris93Si's Avatar
Default Re: 95 Accord won't come out of park. HELP! (civicVX)
I'll have to check, thanks for the reply
Old Sep 1, 2003 | 05:14 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicVX &raquo;</TD></TR><TR><TD CLASS="quote">do the brake lights work? if they don't most likely it is a bad brake switch.</TD></TR></TABLE>
A blown fuse could do it too.
Old Sep 1, 2003 | 05:17 PM
Chris93Si's Avatar
Default Re: 95 Accord won't come out of park. HELP! (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
A blown fuse could do it too. </TD></TR></TABLE>
What fuses should I check?
Old Sep 1, 2003 | 05:52 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Well my sisters car won't come out of park, it'll come out when you use the key to unlock the shifter but not unless you do that. I'm assuming there is some type of interlock or relay that tells the transmission whether or not the brake is on and allows you to shift outta drive and that maybe it has gone bad. So what do you guys think? Is this a common problem? Thank you very much for any help!
Modified by Chris93Si at 7:52 PM 9/1/2003</TD></TR></TABLE>
The problem sounds like the SHIFT SELECTER SWITCH located under the console below the shifter. When it goes bad ... it does not let the shifter know that you are trying to come out of park when you step on the brake. You can see a picture of it here ... (it is part #2)
http://www.hondaautomotivepart...LEVER
Old Sep 1, 2003 | 06:16 PM
Chris93Si's Avatar
Default Re: 95 Accord won't come out of park. HELP! (mwkirchner)
Great info, thanks
Old Sep 1, 2003 | 09:55 PM
im_the_teacher's Avatar
u bet you it is your brake switch.....here a test: make sure everything is quiet step on the brake pedal,,(car off) u should hear a click at the shifter console,
bdub5226
Aug 15, 2011 08:48 PM
lil_kev
Mar 17, 2008 04:02 PM
tisoy281
Jun 3, 2007 07:19 PM
tallyturbo
Dec 24, 2005 02:57 PM
