Full JDM Exhaust and Header !!!
Old Aug 17, 2001 | 07:28 AM
01itr518's Avatar
New User
Default Full JDM Exhaust and Header !!!
I was just wondering why nobody seems to just get the full JDM OEM exhaust system, including the 4-1 header, cat, and cat-back exhaust. Wouldn't this accomplish everything in one bang...the 2.5" collector, the perfectly matching cat, and a perfectly matching exhaust.
Wouldn't this just be a straight swap on our USDM ITRs, assuming the JDM cat has an O2 bung in the same position?
Old Aug 17, 2001 | 07:35 AM
DutchITR1689's Avatar
Default Re: Full JDM Exhaust and Header !!! (01itr518)
The japanese cat-back system is almost the same as the US/European one. Only a little bit longer because the JDM cat is smaller.
Old Aug 17, 2001 | 07:59 AM
FBP_1171's Avatar
Default Re: Full JDM Exhaust and Header !!! (EuroITR1689)
USDM and JDM are probably not the same, as the cat ID is different. At the very least, the b-pipe has to be different. I expect the muffler is the same.
I was thinking the same thing, but nobody seems to import the whole thing. I would like to know if the JDM b-pipe has the bottleneck that the USDM one does due to the smaller diameter cat. If so, that would be sweet. I'm having my b-pipe welded up with an adapter from SMS to match my cat and remove the bottleneck.
Not sure about the second 02 sensor.
[Modified by FBP_1171, 9:03 AM 8/17/2001]
ITR3189
Aug 1, 2007 09:13 PM
KnowForever
Apr 15, 2006 06:42 PM
austrian type-R
Feb 16, 2004 02:39 PM
mr2kqql
May 21, 2003 09:01 AM
Toda Party
Sep 13, 2001 07:48 AM
