FS: Holley Big Bore, ITR/SI 68mm throttle body
Old Aug 17, 2001 | 06:51 AM
zip's Avatar
zip
Default FS: Holley Big Bore, ITR/SI 68mm throttle body
I'm selling this new Holley 68mm straight through TB for $380 shipped (retail is $400+). It's a direct replacement for ITR and Si applications.
Here are picts of it:
Old Aug 17, 2001 | 08:10 AM
2kGSboi's Avatar
New User
Default Re: FS: Holley Big Bore, ITR/SI 68mm throttle body (zip)
how much HP can one expect to gain from such an upgrade????
Old Aug 17, 2001 | 05:32 PM
zip's Avatar
zip
Default Re: FS: Holley Big Bore, ITR/SI 68mm throttle body (2kGSboi)
It depends on the modifications you have installed. It usually works best with engines with aftermarket cams w/ higher lift, high compression pistons, ITR intake manifold; or if you have forced induction. I wouldn't recommend this TB with motors with ordinary i/h/e.
Old Aug 18, 2001 | 03:11 PM
zip's Avatar
zip
Anyone? How about $360 shipped?
Old Aug 20, 2001 | 09:24 AM
CTR94Joes's Avatar
You got IM
Old Aug 20, 2001 | 11:16 AM
HapaHaole's Avatar
Default Re: FS: Holley Big Bore, ITR/SI 68mm throttle body (CTR94Joes)
holley ****!
Old Aug 20, 2001 | 12:42 PM
Mike M's Avatar
Founding Member
Default Re: FS: Holley Big Bore, ITR/SI 68mm throttle body (yeah LS)
What is the one on the Lower Left ?
TIA
Mike
Old Aug 20, 2001 | 04:54 PM
zip's Avatar
zip
Default Re: FS: Holley Big Bore, ITR/SI 68mm throttle body (TypeRmsm)
The TB on the lower left is a 70mm BBK but needs to be modified to fit an ITR and SI.
CTR94Joes: Your IM from Honda-tech isn't reading anything. Just email me at zipzoo_22@hotmail.com
g23_ej1
Sep 8, 2007 10:08 PM
all_out_jdm
May 19, 2005 08:09 PM
FusionEg6
Dec 5, 2003 08:04 AM
russian_racer
Sep 13, 2002 05:11 PM
