Non-Turbo RX7 injectors
i was wondering what the flow rating was on non-turbo RX7 primary and secondary injectors. this is on the old skool RX7s, not the new 93-current or what ever they are
sweet, the local junkyard just got in 5 old skool rx7s so i want some of those injectors! PM me, i'll see if i can pick ya up a set with plugs
From: the asshole of america..., upstate new york, USA
where do you find the info on oem injectors? ive searched before and couldnt find any kind of listing.
ive seen some rx7s at the yard and also some early 90s 240sx's. do the nissan 240sx come with anything higher than a 240cc/min? also anybody know if any of these injectors are peak and holds or saturated?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 »</TD></TR><TR><TD CLASS="quote">where do you find the info on oem injectors? ive searched before and couldnt find any kind of listing.</TD></TR></TABLE>
i would like to know too!
well, the 87 1/2 and up are saturated 460cc for the n/t and 550cc for the turbo
the 84-87 are 460cc peah and hold, i'm unsure about the rest. the way to tell for the 460cc injectors if they are peak and hold is to look at the color, red is saturated and purple is p/h. also, something with the location of the notch inside the clip
Realize this.. RX7 has "primary" and "secondary" injectors. they are both different flow rates, so to effectively use them on a honda, you would have to get 2 sets of primaries or secondaries to use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">Realize this.. RX7 has "primary" and "secondary" injectors. they are both different flow rates, so to effectively use them on a honda, you would have to get 2 sets of primaries or secondaries to use.</TD></TR></TABLE>
are the primary and secondary different sizes? if not why would you need all primary or all secondary?
im not sure what the stock primaries on the rx7's are, but the #'s i listed above were for the secondary injectors..
Like they all said you will have to get injectors from a couple cars to make a whole set.
