LMA's
My b16a hatch is having alittle bit of a prob right now. At right around 3k rpms there is a pretty loud noise comming from my head. before that there is nothing same as after. Now i have been reading up alot on it and i cant find to much about them. But what i have found out on Lost motion assembly is that Type R ones go for right around 30 dollars a piece and theres 8 . From reading up i found that Omniman uses this : (2000 prelude vtec LMA's are far less exspensive but you will have to use a .040in thick washer under them. they are just as stiff as the ITR LMA's but only cost about 8-9 dollars. i have them in my car and have run them in many engines that i have built with no problems! they look like tear drop shaped valve springs )
All my valves are fine everything is working good but i just need to get that damn noise out of there. Also im running stock b16a cams too.
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultracxnos »</TD></TR><TR><TD CLASS="quote">(2000 prelude vtec LMA's are far less exspensive but you will have to use a .040in thick washer under them. they are just as stiff as the ITR LMA's but only cost about 8-9 dollars. i have them in my car and have run them in many engines that i have built with no problems! they look like tear drop shaped valve spring</TD></TR></TABLE>
yeah i ordered these and they are just a spring and they don't look like your normal b16 or b18c lma but i have not used them yet because i am not sure about them so ominam(sorry about the spelling of your name) do u have any pics of these prelude lma in a head or a pic of them period so we can just see what they look like
