Grease in radiator?
Old Sep 1, 2003 | 08:02 AM
robbin's Avatar
Default Grease in radiator?
I searched but couldn't find anything particularly helpful. I took off my radiator cap yesterday and the seal inside was covered in creamy white stuff.. looked like grease. I think I remember something similar in the coolant when I drained the rad but at the time I just assumed it was from the dirty bucket I used.
What could this be... it doesn't look like engine oil but I haven't ruled out a blown headgasket. btw, this is on a stock b18a integra.
Old Sep 1, 2003 | 08:21 AM
IN VTEC's Avatar
Default Re: Grease in radiator? (robbin)
I've heard from Mitsu guys that it's either grease from new parts that are sometimes lubed (ie: water pump, seals, etc.), or it's from sedimentation caused by using any water wetter type of product.
Old Sep 1, 2003 | 09:54 AM
robbin's Avatar
Default Re: Grease in radiator? (IN VTEC)
I've never used water wetter or anything, but I could see if being some sort of sediment. I guess if there was a lot of oil in my coolant it would float and be fairly obvious and the top of the rad.
Old Sep 1, 2003 | 04:40 PM
TeStUdO's Avatar
Have you noticed any smoking or anything?? Try a compression test, but you should know before you have to do that if your headgasket is blown or not
Old Sep 1, 2003 | 04:47 PM
robbin's Avatar
Default Re: (TeStUdO)
No excessive smoking, and the compression test I did was fine.. but that was 18 months ago.
Old Sep 1, 2003 | 04:52 PM
TeStUdO's Avatar
Default Re: (robbin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robbin &raquo;</TD></TR><TR><TD CLASS="quote">and the compression test I did was fine.. but that was 18 months ago.</TD></TR></TABLE>
time for another one
Old Sep 1, 2003 | 08:09 PM
sleepinonacreeper's Avatar
Default Re: (PIMPASSBEOTCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPASSBEOTCH &raquo;</TD></TR><TR><TD CLASS="quote">if the coolant is milky then you should also check your oil...it could be oil in the coolant.</TD></TR></TABLE>
Old Sep 1, 2003 | 08:50 PM
Stripped Honda's Avatar
99-0104
Default Re: (sleepinonacreeper)
my experance has been that it is a blown head gasket or cracked head to cause this ... do a compression test or a leakdown and that should give you the answer
Old Sep 1, 2003 | 10:01 PM
paulzy's Avatar
Default Re: (Stripped Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">my experance has been that it is a blown head gasket or cracked head to cause this ... do a compression test or a leakdown and that should give you the answer </TD></TR></TABLE>
you hit it right on the nail
Old Sep 2, 2003 | 06:53 AM
robbin's Avatar
I'll have to check again when I have more time but this sounds like it may describe my problem. If I do replace the head gasket, do I need to mill the head and or the block?
Old Sep 2, 2003 | 08:58 AM
99-0104
i would take the head to be resurfaced and checked for cracks like i have said the only time i have seen oil in a radiator in a honda car is when the head has been cracked
good luck
Kafelatte
Jan 10, 2007 10:30 AM
Modern91Hatch
Jul 25, 2006 05:26 PM
Modern91Hatch
Jun 3, 2006 04:21 PM
Ri5e
Mar 18, 2002 03:39 AM
