Leaking coolant HELP
Old Sep 1, 2003 | 07:11 AM
ghost_ridah's Avatar
Default Leaking coolant HELP
For the past couple days i notice that my car was leak coolant, but it was only a few drops here and there, but this morning when i woke up i go to my car and theres ythis huge green puddle under it, i look under the car and i see it leaking from the lower part of the engine block. does anybody have any suggestions on how fix this and how bad is it to be laeking from there, and by the way its a 5th gen
Old Sep 1, 2003 | 11:08 AM
Stripped Honda's Avatar
99-0104
Default Re: Leaking coolant HELP (ghost_ridah)
what lower part of the engine block ?? if it is from the side where the belts are then it is a water pump and if it is from the tranny side then it is likely a hose
Old Sep 1, 2003 | 11:19 AM
Default Re: Leaking coolant HELP (Stripped Honda)
I just got finished inspecting it more thoroughly and found out it is coming from the upper part of the tranny, it look like its coming from a bolt on top of the tranny, any suggestions?
Old Sep 1, 2003 | 12:52 PM
KatyHonda's Avatar
Trans doesn't have any water cooling. It's likely your lower radiator hose, heater hose, bypass hose.
Remove inlet duct and inspect closely around the thermostat housing.
W/ a big leak it should be easy to locate.
good luck
guille595
Jul 22, 2013 08:29 AM
Jibin
Apr 24, 2010 07:42 PM
lax1089
Mar 30, 2007 04:11 PM
Paprika
Dec 21, 2004 04:51 AM
96_GSR
Feb 20, 2004 10:38 AM
