1997 Accord needs new timing belt--where to get tool?
Old Sep 1, 2003 | 07:07 AM
syldacat's Avatar
New User
Default 1997 Accord needs new timing belt--where to get tool?
We want to replace the timing belt on our 1997 Accord EX (automatic Trans) but need to get a certain tool to hold the crankshaft pulley still while removing the nut. Does anyone know where we can get one---or even what is the proper name for it?
Thanks.
Old Sep 1, 2003 | 11:07 AM
Stripped Honda's Avatar
99-0104
Default Re: 1997 Accord needs new timing belt--where to get tool? (syldacat)
use a air impact ... take it to a tire shop and ask them to break it loose for you then drive home and take it apart
Old Sep 1, 2003 | 01:06 PM
KatyHonda's Avatar
The tool you need is the Harmonic Damper Pulley Puller from Schley. I bought one from ToolParadise.com for $48 inc. shipping. You will also need a 1/2" breaker bar, 3/4" breaker bar and maybe a cheater pipe for added leverage.
Attach the Schley tool to the 1/2" breaker bar and jam stop breaker bar against the ground or car frame to resist turning. Then muscle up and break the bolt w/ the 3/4" breaker bar and cheater pipe as needed.
As Stripped Honda says you can get a shop to break the bolt w/ an air impact. However, a 1/2" air impact may not do the job. My cheap 1/2" air impact didn't work for me. It may take a 3/4" air impact to break the bolt. I took mine to Honda on one occasion for them to break loose. They use the procedure I described above.
good luck
Old Sep 1, 2003 | 05:40 PM
v4lu3s's Avatar
RTFM
i gotone from ebay for like $25 shipped
works like a charm!
Deviant117
Feb 28, 2011 02:22 PM
pityocamptes
15
Mar 31, 2010 10:41 AM
vrrodri
Aug 27, 2006 11:24 AM
jca1972
Feb 21, 2006 01:49 PM
90teggyls
Feb 20, 2003 08:28 AM
