90-93 interior problem
Old Sep 1, 2003 | 04:43 AM
rice virgin's Avatar
Default 90-93 interior problem
hey all, i got a problem ..i got a 90 accord and i bought a chrome gauge bezel and white face gauges..problem is i cant get my old gauges out the only screws i could find were the two top ones and the one srcew behind the coin/key holder..if any one one has done what im tryin to do i would appreciate any help on how to do it..thankxx !
Old Sep 1, 2003 | 06:33 AM
dynomax27's Avatar
Default Re: 90-93 interior problem (rice virgin)
SEARCH!!!
Old Sep 1, 2003 | 09:26 AM
Default Re: 90-93 interior problem (dynomax27)
i did ..didnt find ****
RUBZERK's Avatar
LOOK IN & UP IN THE AIR VENTS
Old Sep 1, 2003 | 06:02 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice virgin &raquo;</TD></TR><TR><TD CLASS="quote">hey all, i got a problem ..i got a 90 accord and i bought a chrome gauge bezel and white face gauges..problem is i cant get my old gauges out the only screws i could find were the two top ones and the one srcew behind the coin/key holder..if any one one has done what im tryin to do i would appreciate any help on how to do it..thankxx !</TD></TR></TABLE>
You have to remove the air vents to access some of the screws. You also have one behind the dimmer switch. Be careful prying on it when you take it out. Best to get it hot by either leaving it out in the sun with the windows up or use a hair dryer to get it hot. Pry easy ... it will break very easy.
Old Sep 1, 2003 | 09:21 PM
Starrman85's Avatar
Default Re: 90-93 interior problem (mwkirchner)
you'll also need to remove teh stereo, ash tray, tray to the left of steering wheel, vents, all climate control buttons. its really a PITA. then, when you get all that off, theres another 4 screws holding the gauge cluster in. then theres 3 plugs that are easy to get off, but a pain to get back on the gauge cluster.
did i mention its a pain in the ***?
btw: it me over 2 hours to take it all out, and put some reverse indiglo's on mine, then put it back in. so leave urself some time.
AND BE PATIENT!!!
Old Sep 1, 2003 | 09:41 PM
NathanMorris's Avatar
Default Re: 90-93 interior problem (STARRMAN85)
it's hardly worth it, but ya, basically there is a screw behind everything in the dash to get it off. Good luck,
Nathan
Old Sep 2, 2003 | 05:31 PM
ChaosUnbound's Avatar
Default Re: 90-93 interior problem (92Lx)
there is one screw behind each of the 3 vents
one behind tray near door
2 above gauges
2 above radio
1 behind the 3 button things that you have to pop out
2 at the bottom of trim under ashtray and behind cigarette lighter
13 screws in all not including the fact you have to remove the radio
i got eurolite blue carbon fiber gauges took me 5 hours to put it all together and iv taken it apart 4 times sense then. iv got it down to where i can strip it in 10 minutes now also if you remove the top of the steering column cover its a lot easier to remove the trim
good luck on removing that top plug on the gauges its a bitch along with the bottom right one
Old Sep 2, 2003 | 08:14 PM
thenick's Avatar
Default Re: 90-93 interior problem (ChaosUnbound)
get a haynes
Old Sep 3, 2003 | 04:27 PM
Default Re: 90-93 interior problem (ixiblindixi)
o my god! , thankxx guys , well i guess ill try to hit it this weekend..l8r
Old Sep 11, 2003 | 04:37 PM
alright ...i got every screw out except the climate control ones..is it the the round climate heat control and fan blower control or the ones that makes the ac/heat where to go...floor,windshield,face etc..?? and how did you pull them out ..did you pry with a screw driver or just pull straight out?..thankx..l8r
Old Sep 11, 2003 | 06:20 PM
why would you what to remove anything from the ac controls you don't need to touch any of that there are just 2 screws that hold the trim on right under the piece that goes between the ac and stereo
Old Sep 11, 2003 | 06:44 PM
well you said to take out the three button thing ..so i figured you talking about the ac/heat controls...
Old Sep 11, 2003 | 06:57 PM
aww no no im sorry i was vague what i meant was the hazard, rear defrost, and the sunroof/cruse buttons that just pop right out and there is a screw behind them also the dimmer switch has one
KidFrost
Apr 6, 2009 01:44 PM
cowbois3
Aug 7, 2003 10:50 AM
