oil pan gasket replacement for 90 civic si
Old Aug 17, 2001 | 03:16 AM
HankYee's Avatar
Default oil pan gasket replacement for 90 civic si
Hi,
When replacing the oil pan gasket for my 90 civic si do i reuse those 4 dowel pins or sleeves that go in the studs on the ends of the oil pan? The manual i have does not mention these. It does mention a heavy dose of gasket sealer.
Any info would be appreciated.
Henry
Old Aug 17, 2001 | 08:49 AM
DragII's Avatar
25 Year Member
Default Re: oil pan gasket replacement for 90 civic si (HankYee)
unbolt oilpan....scrape of gasket residue from block....install new gasket w/ hondabond/silicon gasket maker....bolt oilpan back up...easy as that
Old Aug 17, 2001 | 02:22 PM
BreakStuff's Avatar
New User
Default Re: oil pan gasket replacement for 90 civic si (DragIIcivic)
Those little metal o-rings were once embedded into the old gasket where the 4 studs would go.. If you have an OEM gasket, you would be able to feel the same o-rings embedded in that gasket as well...
Make sure the o-rings from the original gasket are NOT on the oil pan studs..If you forget to remove them, the gasket will leak, I've seen this done on numerous occassions...
Old Aug 19, 2001 | 12:30 PM
HankYee's Avatar
Default Re: oil pan gasket replacement for 90 civic si (BreakStuff)
Thanx BreakStuff.
Doin the job twice isnt in my schedule.
Henry
v8killaz
Oct 28, 2011 06:33 PM
lymanator
May 7, 2010 07:56 PM
dth0ng69
Jul 14, 2009 08:28 PM
Corporation
Aug 25, 2005 05:20 PM
James
May 11, 2004 01:38 PM
