Hasport Mounts and Edelbrock intake manifold??????
Old Aug 31, 2003 | 06:09 PM
turborex's Avatar
Default Hasport Mounts and Edelbrock intake manifold??????
I am wondering if you can fit a Edelbrock intake manifold with Hasport mounts in a CRX with out to much modification? I have it in my car currently but with the Place Racing mounts and it sits close to the fuel line now. Will it hit the fuel line with the Hasports??? I am putting my built motor in and need to know ASAP?
Old Aug 31, 2003 | 08:34 PM
Fobtions's Avatar
Default Re: Hasport Mounts and Edelbrock intake manifold?????? (pimpracer)
it should clear just fine. a friend of mine had a huge turbo b18c with his own custom mounts to clear a turbo. the edelbrock still fit perfectly
Old Aug 31, 2003 | 09:21 PM
RexB16's Avatar
Default Re: Hasport Mounts and Edelbrock intake manifold?????? (Fobtions)
you will have no probs with the IM and the hasport kit. in fact, i think the edlebrock clears with more room than the stock IM.
Old Aug 31, 2003 | 09:47 PM
civickiller's Avatar
Default Re: Hasport Mounts and Edelbrock intake manifold?????? (RexB16)
where u from pimpracer ?
Old Sep 1, 2003 | 07:56 AM
Caleb V's Avatar
Default Re: Hasport Mounts and Edelbrock intake manifold?????? (civickiller)
I rewired a DPFI-B16 swap for a customer that had an Edelbrock intake and it leaves alot of room. Only problem is they sit so low the throttle cable needs a custom bracket to keep from rubbing on top of the intake runners. I have no idea if they sell them or they reroute the throttle cable underneath. I didn't look at it real close since I didn't install the swap.
Old Sep 1, 2003 | 05:01 PM
turborex's Avatar
Default Re: Hasport Mounts and Edelbrock intake manifold?????? (Caleb V)
Thanks for the info. Will be back in for the weekend.
Charl3Brwn
Jun 15, 2009 07:16 PM
EXEGCoupe93
25
Sep 2, 2007 07:49 PM
Zero2SixtySound
Nov 24, 2005 10:00 AM
SpoonSleeper
Oct 11, 2005 12:39 AM
