6puck with stock pressure plate?? need help fast
Old Aug 31, 2003 | 02:07 PM
iwouldHITit's Avatar
Default 6puck with stock pressure plate?? need help fast
will this effect the prefomance of the clutch??would it worn it down faster if i use the stock pressure plate? cause i got a act heavy duty plate for free but its not in good shape and looks kinda rusty..
Old Aug 31, 2003 | 03:23 PM
Default Re: 6puck with stock pressure plate?? need help fast (iwouldHITit)
help
Old Aug 31, 2003 | 07:42 PM
fox297's Avatar
The pressure plate looks a bit dirty but it should be okay, as long as there's no crack or anything broken. Stock disc will last longer than the 6 puck, but the 6 puck will grabs harder. Depend on what you're looking for, durability or performance, just have to sacrifice one or the other.
Old Sep 5, 2003 | 03:08 AM
mattb16a1civic's Avatar
i would only suggest a 6puck on an heavy duty pp. but also check to make sure it isnt warped, use a straight edge and a feeler guage call act, which i think thats what pp that is and see what the max spec is for pp runout and stuff of that nature. i think thats all i had to say
Old Sep 5, 2003 | 03:09 AM
i think messed up instead of calling act if its stock check a honda manual.
Old Sep 5, 2003 | 03:11 AM
im also it looks like there is alot of wear on the ppl on the actual mating surface, and the fingers look to have alot of wear, id suggest buying a new one if you can afford it, wow its supposed to be smooth or at least mine is not with a lip like that
Absentmind
Jun 23, 2004 08:53 PM
SofaKing
Sep 23, 2003 12:41 PM
chingchong
Mar 30, 2003 09:18 PM
chingchong
Mar 30, 2003 08:59 PM
ericlee303
Nov 14, 2002 01:32 PM
