Hydrolocked yesterday. Life sucks.
Old Aug 31, 2003 | 09:01 AM
VTECorona's Avatar
Default Hydrolocked yesterday. Life sucks.
Getting water out, changing oil, changing plugs and then praying everything is ok. Coolant and oil is still full so I don't think the block cracked at all. Anyone have any suggestions?
Old Aug 31, 2003 | 12:12 PM
TeStUdO's Avatar
Default Re: Hydrolocked yesterday. Life sucks. (VTECorona)
just let it sit for awhile to dry it out, hopefully everything is ok for startup
Old Aug 31, 2003 | 01:04 PM
JCushing's Avatar
happened to me a few months back... had to put in a new motor cause i would up loosing some compression in 1 cyl.
Old Aug 31, 2003 | 01:35 PM
asmallsol's Avatar
Default Re: Hydrolocked yesterday. Life sucks. (JCushing)
Pull the plugs, pull the fuse for the ECU, then turn the car over. Water will get out, Then just leave the plugs off and let the rest dry.
Old Aug 31, 2003 | 02:14 PM
VTECorona's Avatar
Default Re: Hydrolocked yesterday. Life sucks. (asmallsol)
Well, I got it running. I let it idle until it got to running temp (10 minutes rougly) then cut it off. So far so good, who knows what kind of damage is done though. Compression test comes tomorrow.
Old Aug 31, 2003 | 02:28 PM
hybrid93SIvic's Avatar
damn...that sucks man i hope the best for you
Old Sep 2, 2003 | 07:59 AM
VTECorona's Avatar
Default Re: Hydrolocked yesterday. Life sucks. (hybrid93SIvic)
Well, took it for the first ride today. Drove it about a 1/2 mile to 7-11 on back roads staying between 2k-2.5k and then I took the main road on the home staying between 2.5k-3.5k. Ran with no problems but I still have yet to do a compression check to see what kind of condition it is really in.
Old Sep 2, 2003 | 08:08 AM
GSRGuy17's Avatar
What were the conditions that it happened in? And how much are those corner lenses/rear bumper, btw?
Old Sep 2, 2003 | 10:50 AM
Muckman's Avatar
Moderator in Chief
What kind of puddle did you go through?
Ive had my CAI for 3 years, never any problems with water.
Old Sep 2, 2003 | 11:16 AM
VTECorona's Avatar
Default Re: Hydrolocked yesterday. Life sucks. (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">What kind of puddle did you go through?
Ive had my CAI for 3 years, never any problems with water.</TD></TR></TABLE>
Well, I was just stupid to attempt to drive through it. I had a feeling it was going to happen and I still risked it. to me.
The motor was only idling when it happened so it just turned off and I was like "FUCKKKK". This dude behind me hops out and helps me push it into a parking lot where I parked it and I walked home (this happend about 2 blocks from my house). Came back later and called a tow truck and got it home. Cranked the water out, changed plugs and oil and started it up and let it run for about 20 minutes. No weird noises or anything and it idles at a solid 750 or so. I think I got very lucky but I have yet to do a compression test.
Old Sep 2, 2003 | 11:36 AM
GSRGuy17's Avatar
what about your stuff for sale?
TeStUdO's Avatar
when are you trying the compression test so you know for sure??
Old Sep 2, 2003 | 11:43 AM
VTECorona's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">when are you trying the compression test so you know for sure??</TD></TR></TABLE>
As soon as I get around to it.
Make offers on the bumper and corners
Old Sep 2, 2003 | 11:46 AM
GSRGuy17's Avatar
Default Re: (VTECorona)
I'm assuming they're both Milano Red? I don't know... I could check with the parents... $80 shipped for both?
Old Sep 2, 2003 | 11:50 AM
VTECorona's Avatar
Default Re: (GSRGuy17)
Both? I only have the rear bumper. It has a minor scratch on one side about 1" long. Shipping is probably going to be a grip to TX so I gotta check on that before we finalize any $.
Old Sep 2, 2003 | 11:51 AM
GSRGuy17's Avatar
sorry, I meant the bumper's Milano red. What about just the lights shipped to 75052?
VTECorona's Avatar
I paid 20 shipped for my 98-01's so I'll do that for u if u want.
Old Sep 2, 2003 | 12:01 PM
GSRGuy17's Avatar
that could work out... give me a little time to make a decision
Old Sep 2, 2003 | 12:08 PM
Muckman's Avatar
Moderator in Chief
How big was the puddle and how fast did you go through it? Puddle details are good for reference
Old Sep 2, 2003 | 12:16 PM
VTECorona's Avatar
Default Re: (Muckman)
It was in a flash flood kind of situation. I had no idea that the section of road I was going into was flooded. I had pretty much no where to turn off to so I just risked it and went through. It was just high enough to cover my CAI filter completely I think when a wake hit the car. I got out right after it happened and looked at my filter and it had a good 2"-3" or so of air clearance.
Old Sep 2, 2003 | 12:32 PM
Muckman's Avatar
Moderator in Chief
damn thats enough water to spill in the door when you opened it right? damn weird NE weather lately
Old Sep 2, 2003 | 01:19 PM
VTECorona's Avatar
yeah man, both of my carpets got some water on them
Old Sep 2, 2003 | 02:07 PM
Mr. Softee's Avatar
one time my filter got really wet and my car died. put a new filter in and it started right up.
Old Sep 2, 2003 | 02:36 PM
AngryTroll's Avatar
Default Re: (94goldjungsr)
Do a compression test. If one cylinder is low, you probably bent a rod (the engine can still run pretty good with a bent rod ). The problem with a bent rod is it will flex with each revolution of the engine and it will eventually break.
Old Sep 2, 2003 | 03:48 PM
SICKSOLSI's Avatar
i wanna hear some numbers on the compression test
