B16 harness question
Old Aug 31, 2003 | 05:00 AM
98AccordEX's Avatar
Default B16 harness question
my 90 hatch is a DX. i had another hatch that was a 91 SI. i took it to the yard and before i did i stripped it and took out the wiring harness. so my question is, will the SI engine harness plug into the DX car harness and still have all the right same pins? i know i need to run the extra 5 wires for the VTEC, knock, oil pressure switch, ground, secondary o2 sensor. i tried a search but couldnt find this topic
Old Aug 31, 2003 | 06:03 AM
BIG RICH's Avatar
Default Re: B16 harness question (98AccordEX)
no. to use the si harness you have to change the underdash harness aswell. It's not difficult to modify the DX harness. just read a couple of the websites that tell you how to do it. I actually used the sport compact car mag. that had an article about it.
Old Aug 31, 2003 | 06:42 AM
98AccordEX's Avatar
Default Re: B16 harness question (BIG RICH)
thanks for the response
but i ran into a problem with the DX harness. i'm using this site http://www.angelfire.com/d20/h....html to do the wiring to convert DPFI to MPFI first. well it says that pins B10 and B12 should be empty. well my B12 pin has a green/black wire in it. what can i do with this? is the site wrong? do i just need to get rid of the green/black wire?
Old Aug 31, 2003 | 07:00 AM
Big Bang's Avatar
Dont' worry about that wire, It's there in some and not in others and does nothing.
Mark
prime-R
24
Nov 1, 2009 02:54 PM
88SeeOurEx
Dec 14, 2008 07:29 AM
ef dino
May 11, 2007 10:33 PM
Suck my DX
Sep 7, 2005 06:32 AM
Argetnia
Apr 7, 2005 11:54 PM
