Brake Lights won't shut off.
Old Aug 30, 2003 | 11:30 AM
slowassR's Avatar
Default Brake Lights won't shut off.
I searched but no luck. This girl I know her brake lights will not shut off. Even when the car is not on the brake lights are still on. Could it be a fuse? Any help is awesome.
Thanks,
Slow
Old Aug 30, 2003 | 04:52 PM
JV's Avatar
JV
Who?
Default Re: Brake Lights won't shut off. (PIMPASSBEOTCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPASSBEOTCH &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like your brake light switch on the pedal assembly is stuck.</TD></TR></TABLE>
Also, have the bulbs been replaced recently? Do the lights go out when you depress the pedal? Any problems with the turn signals or parking lights?
Old Aug 30, 2003 | 09:16 PM
Fuuma0083's Avatar
Default Re: Brake Lights won't shut off. (JV)
check your brake fluid levels, you might be low.
Old Aug 31, 2003 | 08:10 AM
slowassR's Avatar
Default Re: Brake Lights won't shut off. (Fuuma0083)
Thanks Ill pass the info along.
Old Aug 31, 2003 | 08:37 AM
Patch's Avatar
Default Re: Brake Lights won't shut off. (slowassR)
Mine did this about 2 months ago. You have a small tab on the brake pedal that constantly holds a button down. When you push the brake pedal down, the button is released and activates your brake lights. The small tab on my brake pedal broke off. I put a bolt and some washers in its place and fixed it.
Old Sep 2, 2003 | 08:36 PM
SOUNDEFFECTS's Avatar
Default Re: Brake Lights won't shut off. (Patch)
Patch, has the right answer...or use a flyer card from the strip club that you find in the back seat and fold it couple of times. Worked for me in a jam!
Old Sep 3, 2003 | 08:43 AM
slowassR's Avatar
Default Re: Brake Lights won't shut off. (SOUNDEFFECTS)
That was it. I sent her this thread and problem solved. honda-tech.
Thanks again,
Slow
chighizola9
Jul 20, 2013 01:46 PM
brndnhlcmb
May 1, 2010 08:44 PM
Nocturnal
Sep 24, 2005 12:23 PM
94TealGSR
Oct 25, 2002 11:41 AM
