tell me how to loose weight???
Old Aug 30, 2003 | 11:16 AM
turbociv's Avatar
Default tell me how to loose weight???
well just got back from the track last night. 1/8mi
reaction........1.040
60ft..............2.194
330..............6.064
et@594ft.......8.689
1/8 et...........9.285
1/8 mph........75.49
gimme some advice here so I can improve my 60fts and times. My setup is a lsvtec with 11.7:1, stage 3crowers, mild head work w/ skunk 2 intake, and lightened flywheel and crank pulley, ys1 gsr tranny with lsd. vafc tuneing, I went and got tuned but the dyno wasnt calibrated so I just got my af ratio tuned good. NO cam timing(etc).still set at zero.
any way I was running khumo victor racers that were completely bald, my best time was launching at 3500-4000rpm. Now I know my 89si hatch is a hog. I am assuming that with the motor swap and my body weight I am around 2500lbs or so full interior.
How can I save some weight with my car. Up for all suggestions. I need to get this thing into 12's.
Old Aug 30, 2003 | 11:24 AM
Spirit Iron knife's Avatar
Default Re: tell me how to loose weight??? (turbociv)
A sensible diet, and exercise are the best tools to use for losing unwanted pounds.
I don't think your car is quite that heavy, and you stated that your tires were bald, and that your car really isn't completely tuned yet, maybe more practice is needed once your cars shortcomings are taken care of?
Old Aug 30, 2003 | 11:28 AM
-KangaRod-'s Avatar
yeah 2500 lbs is like as heavy as the new hatch almost. I'd be suprized if your car weighed 2200 lbs.
Old Aug 30, 2003 | 11:29 AM
turbociv's Avatar
I believe that the stock si weighs in at around 2280. correct me if I am wrong.
Old Aug 30, 2003 | 11:33 AM
rodrez.'s Avatar
Default Re: (turbociv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv &raquo;</TD></TR><TR><TD CLASS="quote">I believe that the stock si weighs in at around 2280. correct me if I am wrong.</TD></TR></TABLE>
I think that's how much my Si weighs, it's a 93 hatch. For some reason, I though the 88-91 hatches were lighter than my fat pig.
Old Aug 30, 2003 | 11:35 AM
turbociv's Avatar
http://www.hondaswap.com/refer...eight
ok I found a site saying it weighs in at 2161lb stock
I guess the 90-91 si weighs at 2291lb.
Old Aug 30, 2003 | 11:36 AM
dmotoguy's Avatar
well... stripping our interior would be a good way to loose some of that weight, i just got done stripping my crx.. you would have to put a seat back in.... but thats about it
Old Aug 30, 2003 | 11:40 AM
turbociv's Avatar
Default Re: (dmotoguy)
did you weigh how much you took out. How much weight do you think you saved?
Old Aug 30, 2003 | 11:42 AM
turbociv's Avatar
I was thinking about replacing my rear hatch window and the rear sides with plexi glass. Real light and durrable and not even close to the price of lexan(spelling). how much do you thjink I would save by replacing those. I know the windows are heavy.
Old Aug 30, 2003 | 05:42 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv &raquo;</TD></TR><TR><TD CLASS="quote"> I need to get this thing into 12's.
Your gonna need more than weight reduction to get anywhere near the 12's. Right now that's a mid 14 second pass maybe low 14's on slicks. Tune the motor first
Old Aug 31, 2003 | 06:02 AM
f@sth@tch89's Avatar
You havea couple of options for weight reduction.: 1) Lexan all the windows and go fiberglass doors, front clip, dash, sunroof, and hatch. Or 2) Just cut the doors and still lexan all the windows, and get a CF hood.
Gut the car completely...no interior, no saftey beams, gut all the crap under the dash..
Cut the rear bumper beam leave enough to attach the bumper...
hope this helps get you started.........
Old Aug 31, 2003 | 06:37 AM
advanracing62's Avatar
Default Re: tell me how to loose weight??? (fasthatch89)
the Victoracers are the wrong tyre to drag on. The sidewalls are too stiff, try a drag radial at a low PSI and you should be able to launch better, which will lower the 60ft a touch.
Old Aug 31, 2003 | 10:33 AM
TTWS6,'s Avatar
jenny craig
Old Aug 31, 2003 | 12:09 PM
turbociv's Avatar
the times I ran that I posted are slower than if I went to another track. If I go to the 1/4 which is a 1hr away I would be running high 8's. The 1/8 I went to sucks *** and is uphill.
Fasthatch89, thank you that was the kinda response I was looking for.
advanracing62, I was just using tires I had laying around, I didnt want to burn up my street tires. I just took the tires off and half of the tires was wire.lol I am going to pick up some slicks.
Old Aug 31, 2003 | 12:38 PM
turbociv's Avatar
who sells fiberglass doors and front ends, or is it something I should attemp myself..lol
Old Aug 31, 2003 | 01:36 PM
dmotoguy's Avatar
http://www.mmrusa.com sells all the fiberglass parts you need, but be prepared to spend some $$$... DIY lexan might be a good idea
Old Aug 31, 2003 | 04:36 PM
ranta18's Avatar
check out this site for fiberglass stuff. better prices than mmr. best way to lighten up your car after gutting it. http://www.imagineengineering.com/fiberglass.htm
Old Aug 31, 2003 | 06:57 PM
turbociv's Avatar
the money part isnt to bad for the product but it probably costs an arm and a leg to ship.
Old Aug 31, 2003 | 10:17 PM
ranta18's Avatar
Yeah, shipping is a killer. If you get a 1pc front end, then you can put doors, hatch, etc in the same box any only pay for 1 shipping price. Its less than $300 for a 1pc. You can email me at ie@imagineengineering.com if you need any specific shipping quotes.
GIZZ - EXV
Honda CR-V & Element
Feb 1, 2012 11:12 AM
4RODO
Oct 25, 2007 09:09 AM
dragaholic
Sep 25, 2004 08:15 AM
SagaGSR
Mar 2, 2002 11:57 AM
revsportz
Aug 6, 2001 01:48 PM
