Will this rad fit?
Old Aug 30, 2003 | 10:32 AM
4genaccordfreak's Avatar
Default Will this rad fit?
My buddy has an 89 hatch.. ZC/Turbo'd and the rad as we all know goes across ther whole front end of the engine bay. basically restricting cold air flow, and only feeding hot air to the turbo... i was wondering if u guys think a 92-95 civic rad (which is half the size) would fit without any bigtime modification? thanks
Old Aug 30, 2003 | 11:56 AM
R6Boy69's Avatar
Default Re: Will this rad fit? (4genaccordfreak)
they dont fit to well without modification to the front crossmember... they are a little taller than the stock rad... you can make it fit by leaning back towards the tranny and making a custom braket to hold it up top... I would just get a 90-93 teg rad though.. double core but its a full length rad
Old Aug 30, 2003 | 04:47 PM
sporkcrx's Avatar
Default Re: Will this rad fit? (crXBoy69)
Here's mine. You have to hack away at the rad support to get it to fit. I also hacked a little of the hood skeleton.
Old Aug 31, 2003 | 10:13 AM
Drumwurks's Avatar
Default Re: Will this rad fit? (sporkcrx)
I have one too. What I did was:
1: Removed the front crossmember
2: Threaded tie rods with eyelets on the radius rods
3: Welded together a new crossbar with the rad mount lower in it
4: Welded tabs on the crossbar for the radius rods to mount to
5: Bolted it up to where the old tow hooks used to bolt to.
No hacking, and makes for a much more solid front end
IM for pics if you want.
Old Aug 31, 2003 | 12:19 PM
714phil's Avatar
Default Re: Will this rad fit? (Drumwurks)
or you could buy a place racing crossmember for 160 bucks and call it a day.
Sean5826
Jul 16, 2008 10:40 AM
b16a4
May 28, 2007 06:37 PM
otto
Apr 17, 2005 12:54 PM
