just replaced both axles and they click when turning.....?
just put 2 remanufactured axles in my car last night.......but it clicks when i'am turning......before install it would click basically all the time.......now I have been told that the axles I got, had grease in the boots already but I didnt check......should I drive my car some more and see if the sound goes away? What should I do?
its only clicking when I turn right........and it clicks loud....never did this before......so would I need a new right or left axle?
It could be either, try driving arround in a circle arround someone in both directions to try and determine which one is clicking. Rebuilt axles almost always come prelubed but you never know.
Reman axles will do that, most have a warrenty.. Take them back, get OEM or http://www.raxles.com axles.. Never, EVER get autoparts remans..
here is a freak possibility. when i owned my saturn i had the same problem. so i replaced the axels. still clicked. what ended up being the problem was the motor mount was starting to go. when ever i would turn it would have enough pressure to break through the rubber and make that clicking sound. worth checking it out at the least.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes »</TD></TR><TR><TD CLASS="quote">here is a freak possibility. when i owned my saturn i had the same problem. so i replaced the axels. still clicked. what ended up being the problem was the motor mount was starting to go. when ever i would turn it would have enough pressure to break through the rubber and make that clicking sound. worth checking it out at the least. </TD></TR></TABLE>
wait.. a saturn braking a motor mount... ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">
when you drive a saturn like its a ferarri it doesnt last too long
</TD></TR></TABLE>when you drive a saturn like its a ferarri it doesnt last too long
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
Rywire
Apr 12, 2003 10:32 PM
-=TWITCH=-
16
Apr 6, 2002 09:22 PM
