Anyone done Si/Dx brake swap to 88 HF???
I just got the brake calipers from a 1988 CRX Si however i didn't get the caliper mounting bracket or any other hardware besides the caliper. I know i will need Si rotors to do the brake upgrade however will my HF brackets hold the Si calipers? I was told all i needed were the rotors and calipers... ANYONE KNOW!!!
THANKS!
THANKS!
I dunno. It might be a good idea to get the whole knuckes that way you get 26 spline hubs (which everything beside the STD and HF had) so if you ever swap that is one less thing to do. However you would need new axles. But it would be worth it in the long term.
Well my car just had a D16Y8 swapped into it...but i don't know about the axles and what else is down there...i was told the brake swap was an easy "bolt on" mod. But now i don't know what the heck else i need. Pleas help!!!
ceyazzie
24
Nov 25, 2007 05:54 AM
allmotorEG-SI
Mar 31, 2002 05:17 PM
