What fuel pressure are you hi c/r guys running?
I have my 11.8c/r ls/vtec running 52psi with vacuum connected just to keep from running really lean, not sure if this is normal psi??? I have no engine management whatsoever except a vision chipped p28... GSR cams, milled head, decked block, .25over ITR pistons....
You could drop it down a bit. I got a few extra top end ponies by droping the fuel pressure from 40 to 37 with vaccum. This is on a B16 with 11.2:1. A dyno will tell you the truth.
look one of my friend is running a b18c5 with the same c/r you got and hes runnig a holley 255 fuel pump at idle his fuel pressure is 46 with 244 injectors blueprited
underpressure02
Oct 21, 2005 05:44 AM
Mr. Softee
Mar 6, 2002 05:28 PM
