emblem removal
Dental floss is a good idea...never tried it thou.
You can carefully peel/scrape off the emblem with a thin and firm hard plastic putty knife. And the remaining adhesive you can remove with alcohol or WD40. if you used WD40...make sure u clean it all off with soap and water afterwards.
