whacky Si engine
Old Aug 29, 2003 | 05:31 AM
hdeuce's Avatar
Default whacky Si engine
Ive got an Si motor stuck in an HF and the car will start and run, but when i drive it for a few miles and turn it off, then back on and drive it a few more miles, it starts to spit and sputter/low idle then just shuts off and wont restart...any suggestions/answers??
Old Aug 29, 2003 | 05:48 AM
USDM 4G VTEC's Avatar
Default Re: whacky Si engine (boobstealsgurls)
loose conections???
bad main relay?
bad grounds?
needs a tune up?
Old Aug 29, 2003 | 06:02 AM
hdeuce's Avatar
Default Re: whacky Si engine (USDM 4G VTEC)
Nah im pretty sure the grounds are alright, but what do u mean by loose connections? Not sure of the condition of the main relay. The only thing done to the motor is a milled flywheel.
Old Aug 29, 2003 | 06:11 AM
well loose conections....
check all main wire harness.. sometimes vibrations loose cables up....
its a routine check up....
making sure eveyrthing its tight and in normal conditio
illmatic118
May 4, 2009 02:20 AM
powers89si
Sep 4, 2007 10:57 AM
my2sons
12
May 16, 2007 12:33 PM
PINKS
Nov 15, 2006 03:29 PM
lilbastrd
Nov 4, 2005 08:56 PM
