H22a accord question
Old Aug 28, 2003 | 08:06 PM
WNYAccordLX's Avatar
Default H22a accord question
Well, I swapped the Jdm h22a into my 94 accord lx. Well, obviously the accord power steering line doesnt work. Instead of splicing my existing pressure line, can I just use a 92-96 prelude line.
Old Aug 28, 2003 | 08:53 PM
stRodda's Avatar
Default Re: H22a accord question (WNYAccordLX)
yes exactly. just goto a honda dealership or strip one from a junkyard... or you could always drive without p/s, alot of people choose to do that because it takes a small amount away from the wheels.
Old Aug 28, 2003 | 09:13 PM
NathanMorris's Avatar
Default Re: H22a accord question (stRodda)
pretty much how I've always seen it done.
- Nathan
Old Aug 28, 2003 | 09:43 PM
dvp95's Avatar
Default Re: H22a accord question (92Lx)
mine fit.
Old Aug 29, 2003 | 03:41 AM
v4lu3s's Avatar
RTFM
on a 4th gen the 92-96 lude hose is a direct match but i have not seen it work as well on teh 5th gen accord since the bottom part of the hose at the rack is different.
the wya i ususally see it done is to mod a hose witht he lude upper part and accord lower, or use a 97+ lude hose with the stock accord pump.
Old Aug 29, 2003 | 07:39 AM
pdr's Avatar
pdr
Yes..I tried the 4th gen lude PS line. Didn't work. Just like v4lu3s said the 97+ should bolt right up.
Old Aug 29, 2003 | 11:39 AM
cd7.h22
Guest
Posts: n/a
STOP WAIT ive got your solution...
i recently did this all the other guys said theres went in perfect cuz most likely there valve cover was cut at the cam gear section the easiest thing to do is buy a 97 prelude bracket and use your accord hose and accord ps pump easy as cake thats what i did and you wont need to cut your valve cover
Old Aug 29, 2003 | 11:41 AM
cd7.h22
Guest
Posts: n/a
i still have the prelude pump bracket and hose and ive tried mixing and matching everything my neighbors used his accord bracket but only cuz his valve cover was cut i tried that and it would always hit the valve cover the 97 bracket has the clearance want pix of the set up ill take the pics right now
check this link out also itll help https://honda-tech.com/zerothread?id=591379
Modified by cd7.h22 at 1:04 PM 8/29/2003
Old Aug 29, 2003 | 01:07 PM
does anyone know where I can get a 97 bracket?
Old Aug 30, 2003 | 11:08 AM
cd7.h22
Guest
Posts: n/a
Default Re: (WNYAccordLX)
theres couple people parting theirs out on h-t put up a post or do a search i found 3 last time but the best price was 35 shipped
Old Sep 1, 2003 | 01:46 AM
4gen's Avatar
Default Re: (cd7.h22)
will this work for the cb6, 90-93 accord. can i still use my accord pump or 92-96 prelude pump with the 97+ prelude bracket? thanx
AccludePower
Sep 9, 2006 07:11 AM
hdeucedeuce.cd7
May 16, 2006 02:36 PM
billk2k
Mar 31, 2003 07:41 PM
Jago
Aug 30, 2002 06:35 PM
ZColeon
Aug 16, 2002 08:10 AM
