ECU help
Old Aug 28, 2003 | 03:21 PM
AG3_Teg's Avatar
Default ECU help
I want to upgrade my ECU setup and since I've got an OBD2, which is difficult to find a chip for I'm told, I was thinking of getting an OBD1 ECU and getting that chipped. Are there better or worse OBD1 ECU's to chip or are they all the same?
(I've got a 99 LS by the way)
Also, how much does an OBD2 to OBD1 harness go for anyway?
Any help would be appreciated.
Thanx
Alex
Old Aug 28, 2003 | 04:34 PM
EF_LSVtec's Avatar
Default Re: ECU help (AG3_Teg)
hit blown90hatch...he's the harness guru.
Old Aug 29, 2003 | 03:56 AM
eg6ajk's Avatar
its not hard to mod OBDII to expensive and there isn't much avalibility of programs as well actual hardware need to do it. especially for OBDII non-vtec motors.
there are many different kinds of programs for different non-vtec ecus, some are better other are worse. what can you run: P75, OBDI PR4, P06 as far as ECUs.
ECUs prices will depend on what you want. check my sig.
harness converters are $125-175, depends who you go through.
2manytoyz
Apr 11, 2012 04:49 PM
jennsGSR
Aug 23, 2006 08:34 AM
NsX_CrX
Nov 19, 2005 12:49 PM
WhOIZiT
Aug 24, 2003 01:50 AM
