lighter light, ash tray light
my lighter and ash tray light are not working in my 90 accord dx any suggestions on what is wronge ive looked at fuses and for lose ground or wires none found.
thanks,
jason
thanks,
jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacb7 »</TD></TR><TR><TD CLASS="quote">my lighter and ash tray light are not working in my 90 accord dx any suggestions on what is wronge ive looked at fuses and for lose ground or wires none found.
thanks,
jason
Did you take the counsol apart to look? I think the lighter kinda holds up against the counsol part. But i know there is a plug that connects the light bulb in the ash tray and the lighter. I think they're linked. Correct me if i'm wrong people. Check those and make sure you're turning your headlights on when you're checking to see if they work too...i don't think they'll work if your headlights aren't on. GOod lUck.
thanks,
jason
the ash tray and lighter lights are connected and there is a connector that plugs both of them into another wire if your air-conditioning lights, and your gage lights work then its not a fuse because those are all connected id check bulbs and maybe see if the connector is in good im all too familiar with the wiring of my dash from installing my blue carbon fiber gauges
mines a 92 but should be the same on yours
hey yall thanks for the edvise on the lighter and ash tray light.it was the bulb in the ash tray that was bad. thanks for the replys.
thank,
Jason
thank,
Jason
kovacsa
May 19, 2003 07:16 PM
