??? on t/b size for my motor
Old Aug 28, 2003 | 08:22 AM
EG-cellent's Avatar
Default ??? on t/b size for my motor
I basically have a built b16 at 12.5.1 and p/p head, jun3's etc. and was wondering what sixe t/b to use. I do not want to go too big. Just wanted some insight on what to use. I was thinking like Ericks racining 65 or 68 mm or something like that.
TIA
Old Aug 28, 2003 | 09:05 AM
jwaked's Avatar
Default Re: ??? on t/b size for my motor (EG-cellent)
I would go with the 68 but with your mods (NA) you can´t go wrong with either. Just my opinion
Old Aug 28, 2003 | 09:42 AM
10K2HVN's Avatar
Default Re: ??? on t/b size for my motor (jwaked)
http://www.team-integra.net/se...D=471
Old Aug 28, 2003 | 06:08 PM
EG-cellent's Avatar
Default Re: ??? on t/b size for my motor (10K2HVN)
thanx, I think I am going to order a rpm service 66-68 mm t/b
Old Aug 28, 2003 | 06:44 PM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent &raquo;</TD></TR><TR><TD CLASS="quote">thanx, I think I am going to order a rpm service 66-68 mm t/b </TD></TR></TABLE>
did you even read that link? youll have to sign up first but if your too lazy then it basically says that "65mm plate is more then big enough for most big N/A Teg engines"
thats more then enough at 65mm for 1.8 to 2.0 litters! and your at 1.6L and you wanna get 68mm..?
Old Aug 29, 2003 | 04:44 AM
EG-cellent's Avatar
Yes I read the link it say 70-65 is more than enough and I said I was going 68-66.
Do you think that is still too much.
[QUOTE] A 70mm (at the intake side or TB opening) to 65mm bore (at the plate side) ITR taper bore TB: More than enough for most big N/A Teg engines.[QUOTE]
Old Aug 29, 2003 | 10:30 AM
10K2HVN's Avatar
when they said "70 to 65" they meant 70mm opening tapered down to 65mm tb plate! the opening doesnt matter, only the actual size of the tb plate matters.
yes, i think 68mm is too big for 1.6L NA.
ITR IM and 62mm TB is good for built 1.6L.
Old Aug 30, 2003 | 02:14 AM
AussieK24's Avatar
ITR IM and 62mm Tb is good for any street B series
Old Aug 31, 2003 | 01:36 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: ??? on t/b size for my motor (AussieB20vtec)
Save your tb for the last upgrade, puttting one on anything less then a fully built motor will net you about 1-3hp...
Old Aug 31, 2003 | 05:01 PM
ranta18's Avatar
Default Re: ??? on t/b size for my motor (92 civic VX B18c)
STR 68mm should work nicely with that setup.
Old Aug 31, 2003 | 05:12 PM
Suprdave's Avatar
Stock ITR...
Suprdave
hondaman93
Jul 29, 2007 05:08 AM
TheIceMan
17
Oct 15, 2005 11:52 AM
AllMoToRB18c
Aug 18, 2005 06:31 AM
DeLiRiOu5
Honda Motorcycles
Mar 3, 2005 07:25 PM
