Volk LE37 Question
Old Aug 28, 2003 | 06:37 AM
Dream's Avatar
Default Volk LE37 Question
searched, but couldnt find a answer...
for anyone that is riding on the authentic Volk LE37's, does your wheel(s) have balancing weights? uh if you dont know what balancing weights are, they are the little metal square weights on the inside of some wheels. helps to balance the wheels out.
sorry, I was planning on purchasing this set from someone, but I saw about four pictures and there were about 4 balancing weights on the inside of each wheel. and from my recollection...my old se37k's never had the balancing weights. also the sticker has been removed from the wheels they say. but it should still say "Rays ENG" on the inside of the wheel correct? well someone help me out. thanks.
Old Aug 28, 2003 | 06:44 AM
ekferio's Avatar
Default Re: Volk LE37 Question (Dream)
mine has weights inside & hub centric rings for front wheels
Old Aug 28, 2003 | 06:46 AM
Thrashin's Avatar
if you want your tires to be balanced properly you will need to use wieghts. i dont know why that guy would remove the stickers though, seems kind of funny. it should say RAYS ENG on the front of the wheel in between the spokes.
Old Aug 28, 2003 | 07:45 AM
Dream's Avatar
thanks alot guys. i just want to make sure everything is legit.
Old Aug 28, 2003 | 04:57 PM
JDMHN8's Avatar
Default Re: Volk LE37 Question (thrashin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrashin &raquo;</TD></TR><TR><TD CLASS="quote">if you want your tires to be balanced properly you will need to use wieghts. i dont know why that guy would remove the stickers though, seems kind of funny. it should say RAYS ENG on the front of the wheel in between the spokes.</TD></TR></TABLE>
Again, this is not always the case. A true Volk will have solid spokes (i.e. spokes that don't look like they were hollowed out), the size embossed on the hub mounting surface and they will be light for how large they are. There is a web site that has various wheel weights. should you need to compare. My TE37s do not have RAYS or VOLK embossed on them at all, and they are authentic...
Old Aug 28, 2003 | 05:41 PM
Dream's Avatar
on a te37 or le37, it should have a "Rays ENG" engraved on the inside of the wheel somewhere correct? the person I might be purchasing from says it does not have that engraved anywhere...
Old Aug 28, 2003 | 06:18 PM
ekferio's Avatar
Default Re: (Dream)
i think he's talking about the "Ray Eng" sticker inside the wheel
Old Aug 29, 2003 | 12:30 AM
al4t1gbundy's Avatar
stickers really dont mean anything. i mean i have a set laying in my garage that my wheel shop took off for some unknwon reason, but they are true volks too. keep in mind, some wheels are repolished, fixed, etc and that would practically take off any markings. as far as the stickers on the spokes, they can be ordered through mackin, but only if the owner shows a legit set. (read it somewhere on this forum). and im sure no one makes 17" le-37t copies..dont know if that helps. haha.
Old Aug 29, 2003 | 12:33 AM
nadc2's Avatar
Default Re: (al4t1gbundy)
The only company that i've seen that makes volk le37t's copies are rota's. I forgot the exact name of the rim but I know for a fact that they make le37t copies.
Old Aug 29, 2003 | 02:13 AM
yes rotas make copies (rota grid), but not in 17" i believe&gt;..???
Modified by al4t1gbundy at 4:33 AM 8/29/2003
Old Aug 29, 2003 | 05:34 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Grids are copies of the Volk Gram Light.
Mackin will not get stickers from Rays in Japan. To many copies floating around. I needed a set of volk stockers for my CE28N's and they or the shop I bought it from would/could not help.
Most of the newer style volks that have become popular will have rays eng forged into the wheels itself.
The older volks didn't have this because copies and imitations wern't as prevalent as they are today.
Old Aug 29, 2003 | 08:11 AM
GSR901's Avatar
Default Re: (Apex i ITR)
i have owned a set of attacks and grids and i thought attacks were copies of gramlights and grids of the te37 or le37's...?
Old Aug 29, 2003 | 08:32 AM
SOUNDEFFECTS's Avatar
Default Re: (B18Cwon)
grids are copies of LE37's.period
Old Aug 29, 2003 | 09:48 AM
Apex i ITR's Avatar
Default Re: (SOUNDEFFECTS)
I meant attacks. My bad I forgot the grids. I thought they were the same.
Hard to keep up with all the knock offs.
Cetaylor
Oct 25, 2018 07:52 PM
Stopsign32v
Mar 4, 2015 06:58 PM
G2_Fella
May 8, 2009 08:38 AM
BoostedGreddy
Honda S2000
Jun 28, 2007 11:29 PM
4doorH22
Nov 8, 2002 08:07 PM
