So I need a new tranny...
Old Aug 27, 2003 | 07:31 PM
Bbasso's Avatar
Default So I need a new tranny...
All this time I thougth it was a bad throwout bearing but after the mechanic put a new one in it still makes the noises, He said when the tranny was out of the car he tried to spin the CV outputs and heard a whine sound coming from with in the tranny .
So I guess I have to bring the R in for a new tranny soon - (Under warrenty)
But what bugs me is that it feels fine and I have no problems with driving, just makes a sound when ever I'm in gear that is very hard to explain.
Does anyone have any thoughts on what I should do or look for?
Old Aug 27, 2003 | 08:03 PM
Dan GSR's Avatar
Default Re: So I need a new tranny... (Bbasso)
same syptoms here
except its for a B16 tranny
thought it was the TO bearing
changed the clutch kit and bearing
wasn't the bearing, turns out that the bearing on the clutch housing side of the main shaft had taken a **** and blew up
symptoms were, car drove fine, made a noise, went away when the clutch pedal was depressed, noise was noticeable in everygear at every rpm
I changed the bearing myself a saved a nice hunk of $$$
on the left is the new bearing, on the right is the old bearing, and on the extreme right is the rest of the old bearing...
thank god for the tranny magnet
when i took it apart it needed a really good cleaning, it had a lot of tiny metal particles everywhere and I mean A LOT
Rob get that tranny looked at before it does more damage.
Old Aug 27, 2003 | 08:05 PM
Dan GSR's Avatar
Default Re: So I need a new tranny... (Dan GSR)
another thing to look for is if the input shaft on the tranny
try spining it with your hand if it doesn't go buttery smooth, then its prob the bearing,
if it has any play its prob the bearing,
if it makes some funky noises when you spin it, its prob the bearing
Old Aug 27, 2003 | 08:06 PM
vtec.dc2's Avatar
what type of clutch? and bearing?
Old Aug 27, 2003 | 09:24 PM
migs's Avatar
Default Re: So I need a new tranny... (vtec.dc2)
Time to upgrade to a 4.785FDR
Old Aug 27, 2003 | 09:26 PM
baonest1's Avatar
Default Re: So I need a new tranny... (Migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migs &raquo;</TD></TR><TR><TD CLASS="quote">Time to upgrade to a 4.785FDR </TD></TR></TABLE>
Old Aug 27, 2003 | 10:05 PM
CPR's Avatar
CPR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">All this time I thougth it was a bad throwout bearing but after the mechanic put a new one in it still makes the noises, He said when the tranny was out of the car he tried to spin the CV outputs and heard a whine sound coming from with in the tranny .
Does anyone have any thoughts on what I should do or look for?</TD></TR></TABLE>
I'm in the same boat Rob. My clutch makes this whooshing (sandpaper rubbing-like) noise and it's always at the same range during the clutch travel. When I depress the clutch pedal, during the first 1-1.5 inches of travel the sounds there and goes away for the rest of the travel. When I bring the pedal back up, all is fine until when the clutch starts to enage...at this point the noise comes back and goes away again only when I'm fully off the clutch. My clutch,PP,FW,and T/O bearing has been replaced twice and I'm about to bring it back to the dealership for a possible third replacement. Is my car a candidate for a lemon?
My car also feels fine also even with this noise but it's just annoying.
Good luck w/yours
Old Aug 27, 2003 | 10:09 PM
thk's Avatar
thk
Members Only
Default Re: So I need a new tranny... (CPR)
Interesting. My car has developed that noise too. But it's come and go thing. It doesn't happen all the time.
I guess it's another thing to look for when the tranny gets dropped on Saturday.
Old Aug 27, 2003 | 10:36 PM
DCStreetHtch's Avatar
Default Re: So I need a new tranny... (thk)
i can't tell you fools how happy i am to finally be hearing others with my same symptoms and some results of repair!!!
-Bryan-
Old Aug 28, 2003 | 04:00 AM
Willard's Avatar
hrmm... could this be the same noise that soup's tranny is making?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">I guess it's another thing to look for when the tranny gets dropped on Saturday. </TD></TR></TABLE>
Old Aug 28, 2003 | 06:45 AM
Dan GSR's Avatar
Default Re: So I need a new tranny... (Willard)
maybe we should have marc order some of those bearings now
since acura parts won't be open till next tuesday cuz of the labor day weekend
Old Aug 28, 2003 | 07:16 AM
thk's Avatar
thk
Members Only
probably a good idea. if anything, for a just in case situation. because as we all know, **** happens.
Old Aug 28, 2003 | 08:25 AM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">maybe we should have marc order some of those bearings now
since acura parts won't be open till next tuesday cuz of the labor day weekend</TD></TR></TABLE>
this is an excellent idea....
Old Aug 28, 2003 | 08:55 AM
bus stop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">probably a good idea. if anything, for a just in case situation. because as we all know, **** happens. </TD></TR></TABLE>
you guys need to call him asap.....
Old Aug 28, 2003 | 09:31 AM
thk's Avatar
thk
Members Only
Default Re: So I need a new tranny... (WhosITR)
I already called him.
This might be a fix for the Soups car. My car is probably the throw out bearing (per Dan).
Old Aug 28, 2003 | 03:06 PM
Bbasso's Avatar
Well I'm glad I'm not the only one who has these probelms, or should I be sad that so many people/Tegs have the same kinda problem
Dan, how long did it take you to do all the work to fix the problem?
Also how complex was it to replace that bearing?
As for messing with the 4.7, I think I'll pass- I like seeing 154 once in a blue moon
Old Aug 28, 2003 | 04:42 PM
Dan GSR's Avatar
for working on our cars i'd say that on a scale from 1 to 10 , 10 being the hardest...i'd say this job is either a 9 or 10
took me one day to drop the tranny and open up the case ( dealer was closed by this time so i had to wait till the next day to order the bearing
next day i ordered the bearing
next day i picked it up, found out the bearing was defective when i got home ( of course acura is closed now)
next day i returned the bearing and ordered a new one
next day i picked up the bearing and finished the tranny and drove it the next day
so in all it took me 5 days
if i had the bearing before hand I don't see why it couldn't be done in one day..
for me, it was easily a 10 hour job
Old Aug 28, 2003 | 04:45 PM
Bbasso's Avatar
OH...
I don't have that much time to spare without the R...
I guess I'm going to have to let a shop do it in a day for me.
Could you tell me a part number please?
Old Aug 28, 2003 | 04:49 PM
Dan GSR's Avatar
91004-P21-003 bearing (28x72) the one that broke on me
91216-PH8-005 oil seat, good idea to replace this, as mine was pretty beat up
991002-PS1-003 bearing (28x60) the other bearing, this one didn't get destroyed but had excessive play due to the fact that it was taking more load because the other bearing had blown up
Old Aug 28, 2003 | 04:56 PM
Bbasso's Avatar
Thanks for all the tech help Dan.
Old Aug 29, 2003 | 06:47 PM
CPR's Avatar
CPR
I took my car to Acura tonight to get this noise changed. I also had this weird noise that presents itself when I turn on the AC. The AC noise goes away when I press the clutch down. The tech believes it's the bearing on the main shaft. I'm going back on Tuesday to have their transmission gurus take a closer look.
OT - Do dealerships allow owners to be in the shop while their repairs are being done? I want to make sure that they're actually replacing what they say they're replacing.
Old Aug 29, 2003 | 07:39 PM
Bbasso's Avatar
They usually won't let you in unless your buddies with an insider-
Ins rules... BS.
Just ask for the old peices that were replaced.
Old Aug 29, 2003 | 08:34 PM
asubennett's Avatar
Bearing is the first and easiest thing to suspect but don't overlook a broken tooth on the final drive gear or the pinion gear. I had this problem, thought it was a bearing and it went kablooey! Very messy and dangerous when it decided ot lock up.
Old Aug 29, 2003 | 09:46 PM
CPR's Avatar
CPR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">They usually won't let you in unless your buddies with an insider-
Ins rules... BS.
Just ask for the old peices that were replaced. </TD></TR></TABLE>
I'm not sure I can ask for the old pieces because they have to have something tangible in their records to back the claim of the warranty work.
Old Sep 13, 2003 | 10:11 AM
Bbasso's Avatar
ON Friday I stopped by the Acura Dealer and spoke with the Main man in charge.
This is what he told me, They have a few bulletins out on tranny bearings and it has been a problem for a while now.
It will take approx 3-4 days to rebuild my tranny back to new.
So All I need to do now it get the nerve to leave my R in the dealer for 4 days.
