90 civic dx, ZC motor swap...wiring questions.
Old Aug 27, 2003 | 07:15 PM
manson's Avatar
Default 90 civic dx, ZC motor swap...wiring questions.
i did a seach... i didn't really find what i was looking for SO im writting this post.
my buddy bought a 90 civic DX hatch. he has a ZC motor in his 89 crx si. my question is would we be able to take out the crx si wiring harness and complete the swap by replacing the whole wiring harness in the civic instead of doing the wiring on the dx harness.
im thinking that i may have some issues with the lenth of the wires. like the headlights plugs not reaching or battery wire.
so has anyone done this? i think it would be easier, but i just don't know what i may end up getting into.
your posts are appriciated.
thanks
Old Aug 27, 2003 | 07:33 PM
BIG RICH's Avatar
Default Re: 90 civic dx, ZC motor swap...wiring questions. (mansonclubpuir)
Seriously, it would be easier to modify the DX harness. you would have to change the harness inside the car, if you used the Si wiring. Using the DX harness isn't hard, really. just read a couple of the websites that explain the swap and you should be good if you take your time.
Old Aug 27, 2003 | 08:08 PM
Caleb V's Avatar
Default Re: 90 civic dx, ZC motor swap...wiring questions. (BIG RICH)
I build DPFI-MPFI harnesses all the time. Much easier than replacing a whole car harness.
Old Aug 27, 2003 | 08:53 PM
manson's Avatar
Default Re: 90 civic dx, ZC motor swap...wiring questions. (Caleb V)
see i thought i would have to just change out the engine compartment section of wiring... if i have to take out the WHOLE car harness then its not even worth my time. I guess i just have to make a dpfi to mpfi.
any recommended sites to see for the switch? i have never done anything like this before so i could use all the help i could get. guess its time to start the search.
Old Aug 27, 2003 | 09:21 PM
FourthGenHatch's Avatar
http://www.fourthgenhatch.com/mpfi.html
Old Aug 28, 2003 | 06:16 AM
jlicrx's Avatar
Default Re: 90 civic dx, ZC motor swap...wiring questions. (FourthGenHatch)
by far the best site for this info!!!
Old Aug 28, 2003 | 06:26 AM
USDM 4G VTEC's Avatar
Default Re: 90 civic dx, ZC motor swap...wiring questions. (jlicrx)
to DX to ZC wiring conversion
its not even worthed taking all out of the Si into the car.....
it sbetter to swap 7 wires over a whole harness....
88crxdxfastwhip
Nov 3, 2005 06:46 AM
komat
Oct 16, 2004 03:03 PM
qcoffey
Jun 29, 2003 07:18 PM
RussHondaCRXVtec
May 12, 2003 08:16 PM
JDM HYBRID
Mar 22, 2002 02:57 PM
