Top Fuel Power Neo
Old Aug 27, 2003 | 07:10 PM
JUN JDM's Avatar
Default Top Fuel Power Neo
Does anyone have this for there car?...does it really work?...exactly what does it do for your car...and is it worth the hundred bucks......?
Old Aug 27, 2003 | 09:12 PM
Dream's Avatar
its only a hundred bucks? where did you see it at?
Old Aug 27, 2003 | 09:20 PM
AP Kreuzer's Avatar
Default Re: (Dream)
http://www.raretrick.com has some for 130.00 on a group buy hope that helps and they say it has a 5hp gain
Old Aug 28, 2003 | 09:39 AM
Suk02Si's Avatar
Default Re: (KnightHawkEP)
irrational on ephatch.com has it. He says it didn't really do anything, only a true dyno will tell
Old Aug 28, 2003 | 11:14 AM
TsunamiZC's Avatar
Default Re: Top Fuel Power Neo (JUN JDM)
As seen in Aug. issue of Super Street. Power Neo is attach to your fuel line before the FPR and internally there's a series of magnets, which charge up the fuel, creating a constant and even flow, thereby increasing its efficiency. Tests show a 5hp increase on a stock K20 just for adding the Power Neo. The power NEO which changes gasoline into the super particulate. Installing, it is the effect of the wonder which you realize. - Improvement of fuel economy/average 5 - 30% rises - The exhaust purification with carbon monoxide decrease - Decrease and silence conversion of black smoke of Diesel car - Actualizing entire area power rise - Actualizing entire area torque rise - Response rise - Silent characteristic rise and decrease of carbon - The ignition timing advanced angle due to explosion power rise - As for from bulk injector installing vehicle effective rise. Power NEO installation method 4 these volts/bolts of power N E O loosening is opened with 6 angular wrenches of attachment. The fuel tank and in injection or the jet pump etc. please open the engine hood and insert the fuel hose of the fuel supplier which the joint is done again with volt/bolt. Case of the fuel hose of the pipe diameter 1 2 millimeters, in order to prevent the opening, covering 1 millimeter thick silicon spacer of attachment on the fuel hose, again please insert to power NEO securely with volt/bolt
Old Aug 28, 2003 | 02:05 PM
Chronicsinners's Avatar
Default Re: Top Fuel Power Neo (tsunami_zc)
i would like to see a dyno, an interesting concept
Old Jul 14, 2004 | 07:09 AM
Charlie Moua's Avatar
more info please
A fuel injector is a solenoid. A current passes through the windings and the resultant magnetic forces open the pintle/disc/ etc. Thus you can see that the fuel on any fuel injected vehicle is subjected to magnetic forces already! If the fuel were "polarized" by their magnetic device what do you think would happen when it gets to the injector/solenoids?
Modified by Charlie Moua at 10:33 AM 7/14/2004
Old Jul 14, 2004 | 07:24 AM
krystar's Avatar
I wanna call Tornado BS on this .... but have no factual backings. gut instinct says it's just as effective as tornado.
theorize with me now. a magnet, albeit one powerful enough to align the gasoline molecules so much that if you put this device anywhere along your fuel line, it'll keep the molecules aligned all the way to the fuel injector. even after it gets injected into the chamber, they still stay in alignment and because of that "burn" cleaner and create more power.....yea....right....
Old Jul 14, 2004 | 08:13 AM
Used2beAb16's Avatar
Default Re: (krystar)
man people will buy anything holy ****
Old Jul 14, 2004 | 08:21 AM
jrsc dc5's Avatar
"changes gasoline into the super particulate"... i liked that part, hah.
Old Jul 14, 2004 | 10:14 AM
03ephatch's Avatar
Default Re: (jrsc dc5)
fuel economy/average 5 - 30% rises - entire area power rise - entire area torque rise - Response rise - Silent characteristic rise -to explosion power rise - As for from bulk injector installing vehicle effective rise. [/QUOTE]
not dyno-proven. *tongue out*
what's up with this word being used 7 times?
Old Jul 14, 2004 | 12:37 PM
djvtoner's Avatar
Default Re: (03ephatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03ephatch &raquo;</TD></TR><TR><TD CLASS="quote">fuel economy/average 5 - 30% rises - entire area power rise - entire area torque rise - Response rise - Silent characteristic rise -to explosion power rise - As for from bulk injector installing vehicle effective rise. </TD></TR></TABLE>
look at that genius marketing scheme.... wow
Old Jul 14, 2004 | 10:54 PM
DC5ITR329's Avatar
Default Re: (djvtoner)
Look at some of the stuff top fuel has done. I believe it work but not to those numbers. I think gains are very minimal.
Old Jul 15, 2004 | 09:36 AM
I_HATE_JDM's Avatar
i have had it for a year now....it does NOT fit right over the fuel line...it seems to be made for a smaller line. you can clamp it on there but you can tell it was made for a smaller hose. hp increase? LMAO i noticed NOTHING. its a gimmick that looks cool
Old Jul 15, 2004 | 11:54 AM
DC5ITR329's Avatar
Default Re: (I_HATE_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I_HATE_JDM &raquo;</TD></TR><TR><TD CLASS="quote">i have had it for a year now....it does NOT fit right over the fuel line...it seems to be made for a smaller line. you can clamp it on there but you can tell it was made for a smaller hose. hp increase? LMAO i noticed NOTHING. its a gimmick that looks cool</TD></TR></TABLE>
I'd still get it. lol
Old Jul 15, 2004 | 11:01 PM
ceasar of mgineering's Avatar
▓spam and rice▓
Default Re: (aznbo1626)
call aj-racing.....T1R just came out with one for 87 bucks
Old Jul 19, 2004 | 08:29 AM
Will62185's Avatar
Default Re: (ceasar of mgineering)
https://honda-tech.com/zerothread?id=877929
Old Jul 20, 2004 | 12:35 AM
PYMUGENITR's Avatar
mine should be here this week and I will have it dyno tuned.
Old Jul 20, 2004 | 03:42 AM
memoryfab.com's Avatar
pretz specialist
Default Re: (PYMUGENITR)
We sell this the power neo as well. It's basicly a over powered magnet to help flow of fuel. Option mag has done a dyno of this product compared to a lot of other magnetic products out there.
Old Jul 20, 2004 | 06:17 AM
Kal's Avatar
Kal
looks excessively useless.
Old Jul 20, 2004 | 06:47 AM
rs-sex's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceasar of mgineering &raquo;</TD></TR><TR><TD CLASS="quote">call aj-racing.....T1R just came out with one for 87 bucks</TD></TR></TABLE>
I don't see any mention to it on there site. Have you seen anything?
Old Jul 20, 2004 | 07:40 AM
f1nal zeros's Avatar
It doesn't do ****. Just buying JDM name.
A local RSX owner had it on his turbo RSX and he explained it didnt do ****. Dyno proved nothing.
Oh well, it's like when people buy altezza's, doesn't do **** but it looks pretty. haha
Old Jul 20, 2004 | 08:15 AM
Boost Ambassador's Avatar
Default Re: (f1nal zeros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1nal zeros &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't do ****. Just buying JDM name.
Oh well, it's like when people buy altezza's, doesn't do **** but it looks pretty. haha</TD></TR></TABLE>
Top Fuel here, stop spreading rumors dyno sheets soon to come...
JUN JDM you have no powa, and by the way "I have something for ya" Black dude always on grass...you know who I'm talking bout' cousin!
Old Jul 20, 2004 | 08:20 AM
pretz specialist
I think it is more emissions effective than anything else. The Option article also did emissions testing on each product and you can see a significant result from those readings, but as for horsepower it was between 1-3 which could've been in the margin of error. If you really want to get something like this, just buy a charged magnet and wrap around your fuel line. but for the bling would you pay 100+?
It's like paying 800+ dollars for a mugen or arc box intakes.
Old Jul 20, 2004 | 09:17 AM
DC5ITR329's Avatar
Default Re: (memoryfab.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memoryfab.com &raquo;</TD></TR><TR><TD CLASS="quote">
It's like paying 800+ dollars for a mugen or arc box intakes.</TD></TR></TABLE>
What wrong with paying for a 650 dollar intake from mugen? That's quality stuff. I think ARC is nice stuff to. If you want good high end stuff. You can't pay practically nothing for it unless it's copied.
