Crv oil Pump same as ITR and GSR, but for what year??
Old Aug 27, 2003 | 05:18 PM
Dragger817's Avatar
Default Crv oil Pump same as ITR and GSR, but for what year??
i keep hearing peple talk about the crv block having the same oil pump as GSR and ITR, but for what year does that apply to?? I have a 96 CRV block is my block too old?? Do i really need an ITR oil pump or a GSR one?? Whats the part number on that if any knows, Thanks!
Old Aug 27, 2003 | 06:50 PM
TECH43 RACING INC.'s Avatar
Default Re: Crv oil Pump same as ITR and GSR, but for what year?? (Dragger817)
non vtec and vtec have different oil pumps. vtec ones flow more oil at a higher pressure. use any vtec oil pump if you are using a vtec head...otherwise...non vtec is fine.. the cheapest is the type r/99 si. but you have to run a us 96 up lower cover the clear the mounts for the crank fluctuation sensor.
Old Aug 27, 2003 | 08:22 PM
TREVER's Avatar
Default Re: Crv oil Pump same as ITR and GSR, but for what year?? (TECH43 RACING INC.)
Not to argue ( nice sig), but I know that some of the crv's oil pumps were the same part number as the type R. I used a crv pump and I make 80 psi no prob same as a r pump. Water pumps are a diff story.
Old Sep 11, 2003 | 09:08 PM
migs's Avatar
Default Re: Crv oil Pump same as ITR and GSR, but for what year?? (TREVER)
Anybody know more information on this?
Old Sep 11, 2003 | 11:33 PM
mmuller's Avatar
Mad Scientist
Default Re: Crv oil Pump same as ITR and GSR, but for what year?? (Migs)
https://honda-tech.com/zerothread?id=615375
search, lots of info on this
JDM_home
Jul 17, 2012 06:38 PM
patrickcrx
Nov 29, 2006 11:16 AM
AMLS4dr200whp
Nov 14, 2006 10:07 AM
LBR92DA-T
Nov 12, 2003 09:16 PM
