rear disc convertion question
i know this is so played out ........... but i have a qwik one i have all the stuff from a 90 teg........
do i need inner break lines aswell as outter?
will a 91 DX shock bolt to the teg parts?
thanks guys
thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitekidsef9 »</TD></TR><TR><TD CLASS="quote">sorry its a 91 DX</TD></TR></TABLE>
a 91 DX hatchback or a 91 DX CRX? reason asking because of the difference in e-brake cables. If it is a CRX them use the e-brake cable from a 90-91 CRX si, if it is a hatchback then I believe you can use the 90-93 Teg e-brake cables. You can still use your shocks but you have to use your old LCAs....
For Civic Hatch use 90-93 Integra Coupe Brake Cables
For CRX use 90-91 CRX Si Brake Cables
For Sedan use 90-93 Integra Sedan Cables
As for brake lines you can use 90-93 Integra ones or 90-91 CRX Si ones, they are all the same.
tigueremalo
May 31, 2006 01:08 PM
jb0705
May 16, 2006 11:00 AM
Norcalstoppy
Apr 30, 2003 03:53 PM
