fastest allmotor b16
stock bottom end JUN III cams ran 13.2 @ 3000ft elevation in 98 degree heat... I'm sure that there are faster cars out there.. this would have been 12.8ish at sea level.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">stock bottom end JUN III cams ran 13.2 @ 3000ft elevation in 98 degree heat... I'm sure that there are faster cars out there.. this would have been 12.8ish at sea level.</TD></TR></TABLE>
Didn't you mill the head? What headgasket were you running? If I can get into the low 13s with the same setup in my coupe I'll be very happy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skeletor »</TD></TR><TR><TD CLASS="quote">Didn't you mill the head? What headgasket were you running? </TD></TR></TABLE>
I am not advanracing62 but he was using a stock head gasket, unmilled head, undecked block.
Banned
From: at last finally back to sweet home, sunny north cali, usa
its' all just power/weight ratio. mid 11's is possible, maybe low 11's even. for a real 1.6 motor. not b16a "block'ed" big motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 »</TD></TR><TR><TD CLASS="quote">Are you talking street or track? stock bore or resleeved? </TD></TR></TABLE> as long as it = a 1.6L nothing crazy like a b16a block 86mm bore ls crank...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allm0t0rsir »</TD></TR><TR><TD CLASS="quote"> as long as it = a 1.6L nothing crazy like a b16a block 86mm bore ls crank...</TD></TR></TABLE>
i have a dream....
i have a dream....
I'm not the fastest by far but my times are on a basicly stock motor.
13.9 98mph
Stock JDM B16, I/H/E, chipped p28, no cat.
92 Civic VX on street tires
13.9 98mph
15' slicks at about 12 psi.... The fastest MPH we could muster was 101.2, but on average we were about 99.8MPH. Those slicks killed us... We could have been faster in the ETs if we had some 13"ers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">I'm not the fastest by far but my times are on a basicly stock motor.
13.9 98mph
92 Civic VX on street tires</TD></TR></TABLE> is that all u got in ur b16?!? and u ran those times on street tires? how is it possible for u to run those times? was ur engine a lil bit more healthy then a normal jdm b16??? please explain.
13.9 98mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo »</TD></TR><TR><TD CLASS="quote"> is that all u got in ur b16?!? and u ran those times on street tires? how is it possible for u to run those times? was ur engine a lil bit more healthy then a normal jdm b16??? please explain.</TD></TR></TABLE>
Yep, all I have is what I posted. Dyno'ed 151/105 so it's pretty normal for a b16.
Yup 5 years ago in 1998...
First time EVER using slicks - MT ET Drag 20x6x14... best time was at 18psi
60': 1.937
330': 5.645
660': 8.777 @ 78.80mph
1000': 11.490
1320': 13.791 @ 98.43mph <- click for video
Stock issued 1595cc B16A3 in a 2520lb. delSol VTEC
55 degrees, 30.20 pressure, 75% humidity
Iceman intake, DC header, RS*R Exhaust, DPR Stage VI headwork, ITR cams, 9500rpm redline (gforce chip), ITR lsd, 270cc injectors, Field SFC-VTEC. old-skool, eh?
Lata!
60': 1.937
330': 5.645
1000': 11.490
Lata!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letholone »</TD></TR><TR><TD CLASS="quote">stock block b16a. 1 series.
ctr cams
90 hatch-full interior and running through the muffler.
13.2 at 105mph.
190 to the wheels.113TQ</TD></TR></TABLE>
What else did you have to get 190 on a stock b16? Cams only won't do it for sure.
ctr cams
13.2 at 105mph.
