My N/A Setup...what's next?
Old Aug 27, 2003 | 04:41 PM
hYpE-R-29's Avatar
Default My N/A Setup...what's next?
Here is what I have so far, and I want to get a couple of more things before I go on the Dyno and get more tuning.
2000 Type R
Aem Cai, Skunk2 Cam Gears, Jdm Headers, Carsound Cat, Apexi N1 exhaust, Skunk2 Stage 2 Camshafts, Skunk2 Valve Springs and Retainers, Hondata s200 with P28....NOW what else do I need and what do you guys recommend since I have saved some money.
All help will be great
Old Aug 27, 2003 | 04:57 PM
advanracing62's Avatar
Default Re: My N/A Setup...what's next? (hYpE-R-29)
compression bump! those cams love compression... 11.5:1+
Old Aug 27, 2003 | 04:58 PM
hYpE-R-29's Avatar
Default Re: My N/A Setup...what's next? (advanracing62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">compression bump! those cams love compression... 11.5:1+
whats the best way to bump compression??? ctr pistons??
Old Aug 27, 2003 | 04:59 PM
skribblah's Avatar
lightweight crank pully, maby lightweight flywheel ( i heard toda flywheels are nice) and....
cant really think of anythign else at the moment.
JDM final drive if you wanted to...
Old Aug 27, 2003 | 06:17 PM
BolivianDc2's Avatar
Default Re: My N/A Setup...what's next? (skribblah)
i would say throw in CTR pistons, do you do the work yourself or do you go to a shop? I know a shop will charge an arm and leg if you dont take the engine out of the car to begin with.
Old Aug 27, 2003 | 06:40 PM
hYpE-R-29's Avatar
Default Re: My N/A Setup...what's next? (Bolivianstrtwpn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn &raquo;</TD></TR><TR><TD CLASS="quote">i would say throw in CTR pistons, do you do the work yourself or do you go to a shop? I know a shop will charge an arm and leg if you dont take the engine out of the car to begin with.</TD></TR></TABLE>
most likely a shop...how much do u think it will run?
Old Aug 28, 2003 | 03:09 AM
00 FBP ItR's Avatar
i'd say jdm itr w/ a spoon headgasket, ctr will detonate.
Next on your list:
Bump Compression
Injectors
*A REAL Header/Exhuast setup* toda/smsp.
Clutch/Flywheel?
**TUNING**
I Got the Pistons/Injectors/Clutch/Flywheel, PM me if you're interested.
Old Aug 28, 2003 | 07:38 AM
Default Re: My N/A Setup...what's next? (00 FBP ItR)
I don't think I'd use the CTR for your app... you'll end up with over 12:1 compression and I doubt that you 'll run pump fuel anymore at that point. Go 11.5:1 for the street and you should be fine.
Old Aug 28, 2003 | 07:41 AM
1bad-eg's Avatar
Old Aug 28, 2003 | 02:03 PM
Austin's Avatar
The list I would recommend...the only item on the list that I don't have is the ported head...
JDM Final Drive
Lightweight flywheel
Better Header
Mugen Headgasket
Hondata intake manifold gasket
Ported head
Modified by Austin at 4:26 PM 8/28/2003
Old Aug 28, 2003 | 02:13 PM
Rhetoric's Avatar
Default Re: (Austin)
310cc injectors
higher compression (Mugen gasket or Jdm P30/Mugen)
ported head
All of that alone would probably cost about 1400 in parts/labor unless you do most of it.
Other than that Jdm final drive/clutch/flywheel will compliment your set up very well (as well as your next set up).
JDMThoughts
Nov 21, 2005 07:03 AM
Got Milk
15
Nov 13, 2005 10:05 AM
BLK99VTECR
Aug 15, 2005 08:31 PM
1quickhatch
Sep 8, 2004 01:37 PM
JDMSiGuy17
May 16, 2004 08:53 AM
