Stage 1 or stage 2 cams?
Old Aug 27, 2003 | 11:54 AM
12secB18acivic's Avatar
Default Stage 1 or stage 2 cams?
Wanting to make more power and looking to put some aftermarket cams in my motor. currently I am running ctr cams. I am running with an Lsvtec with 10.5:1 pistons, ported head w/ valvetrain upgrade and all the bolt ons and a chipped p28 ecu. Will i make some power with Skunk stage 2? or should i go with the stage 1? I know i should put some higher comp pistons in , but i can't any downtime cause this is my daily driver. ......so wich stage is best for my setup?
Old Aug 27, 2003 | 12:22 PM
GokuSSJ4's Avatar
Default Re: Stage 1 or stage 2 cams? (12secB18acivic)
IMO stage 2 should be more then enough . if you would get higher CR and forged pistons like JE or arias then stage 3 would be a+ . you sholuld see some nice gains from running stage 2 skunk cams . Stage 1 are just a bit more aggressive then ctr cams so stage 2 would be a better choice ....
Old Aug 27, 2003 | 07:04 PM
Tadeh's Avatar
Default Re: Stage 1 or stage 2 cams? (Spoon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 &raquo;</TD></TR><TR><TD CLASS="quote">IMO stage 2 should be more then enough . if you would get higher CR and forged pistons like JE or arias then stage 3 would be a+ . you should see some nice gains from running stage 2 skunk cams . Stage 1 are just a bit more aggressive then ctr cams so stage 2 would be a better choice ....</TD></TR></TABLE>
Correct but he did mention daily driver reliability. Stage 3 monsters would be a bit too much unless he got some serious tuning. If I REALLY cared about reliability and I had a lengths drive ahead than id definitely get some skunk1's, there nice and mild, as you know there a bit more aggressive than CTR so to me those sound perfect for you but id take stage 2's into consideration also, with some CTR pistons &lt;&lt;seems to be the setup this whole board is going for because it seems to be a good match up. You could definitely lose power with the wrong CR/tuning and a higher lift cam.
Edit: Keyboard went bananas and my reply looked like a 3rd graders paragraph.
Modified by tadeh at 4:23 AM 8/28/2003
Old Aug 28, 2003 | 03:36 PM
Default Re: Stage 1 or stage 2 cams? (tadeh)
so i should go with stage 2?
Old Aug 28, 2003 | 07:24 PM
Tadeh's Avatar
It's up to you. Which setup fits you better.
Old Aug 28, 2003 | 07:33 PM
hayabusa160's Avatar
stage 1 is smog legal they carb exempt.
alexthegrinch
13
Jun 17, 2009 05:08 PM
vitalik
Sep 12, 2006 06:02 PM
Jdmbsixteen
Aug 17, 2003 07:53 PM
SymphonyX
Mar 26, 2003 09:26 PM
