91 crx si cam in 91 std hatch
Not worth it unless you do the MPFI swap. If you do an MPFI swap you should come out close to 105hp. Similar to the D15B7. You will be either 1/2 tooth advanced or retarded due to the deck heights on the 1.5 and 1.6 blocks being different. I would recommend an adjustable cam gear to compensate. Also you now use the timing marks of the 1.6L to set the cam not the 1.5L marks. If you need a DPFI-MPFI wiring harness then send me an email.
