A/F Meter Install, ECU or O2 Sensor,Which is more accurate?
Old Aug 26, 2003 | 10:59 PM
miksew's Avatar
Default A/F Meter Install, ECU or O2 Sensor,Which is more accurate?
Which should I hook up the violet wire to?
Old Aug 27, 2003 | 12:04 PM
.xcalibur.'s Avatar
Default Re: A/F Meter Install, ECU or O2 Sensor,Which is more accurate? (miksew)
the o2 sensor hooks up to the ecu...so hook it up to whereever is convenient for you..i say the ecu so you wont have an extra wire int he engine bay
Old Sep 7, 2003 | 05:46 PM
scatuli's Avatar
Default Re: A/F Meter Install, ECU or O2 Sensor,Which is more accurate? (.xcalibur.)
yeah xcalibur is right they are the same wire
just a heads up d14 on the pr4 obd1 ecu
Old Sep 10, 2003 | 05:49 PM
miksew's Avatar
Default Re: A/F Meter Install, ECU or O2 Sensor,Which is more accurate? (scatuli)
which will give a better reading?
Project91CRX
11
Oct 6, 2003 11:41 AM
