Have some pretty conservative goals....can they be met with.........
Old Aug 26, 2003 | 09:58 PM
MikeMAN's Avatar
Default Have some pretty conservative goals....can they be met with.........
I am currently ordering a b20 block because my old ones headbolts are stripped out, and helicoils or anything aren't working.
Here is my new plan:
ARP Head Studs
b20 block (swap stuff from old block over obviously)
84mm Pistons (probably 11.5:1 compression) on stock b20 rods
Stock B16a2 cams (trying to work some cams into the budget but not sure which will work well in my simple setup)
RC 310cc Injectors
Hondata + OBDI ECU/harness
Before Winter:
ARP Rod Bolts
My Goal:
13's all night on street tires, i figure some nice cams will make this a reality but not sure about the b16a2 cams. This in a full weight 98 ex coupe with b16a2 tranny.
Modified by MikeMAN at 3:04 AM 8/29/2003
Old Aug 26, 2003 | 10:56 PM
igotyofire's Avatar
Default Re: Have some pretty conservative goals....can they be met with......... (MikeMAN)
yea and 13s in what car and what tranny?
hpimichael02
Nov 5, 2008 11:37 AM
snowseeker
Aug 31, 2004 11:33 PM
BLK JDM
Nov 10, 2003 11:32 AM
BLK JDM
Nov 4, 2003 05:14 AM
MikeMAN
Aug 26, 2003 04:41 PM
